Previous in Forum: Do You Have A Fiber Optic Network At Your Company?   Next in Forum: Wind Pressure on PV
Investment Casting Dies
04/24/2011 2:33 AM
Why dies used for investment casting are always made up of aluminium ?
Good Answers: 196
Re: Investment Casting Dies
04/24/2011 8:05 PM
Because the dies are used to make wax preforms of the finished casting. The actual mold for the finished metal part is made out of plaster which covers and surrounds the preforms and whatever wax feed gates that are attached to them. Then the entire "flask" of wax preforms and plaster are baked in an oven during which the wax melts and runs out. This leaves a hollow cavity in the mold which can then be filled with molten metal. After the metal cools and solidifies the plaster is removed in pieces and discarded. The castings are cut away from the gate structure and any bits of plaster stuck on them scraped or polished away.
Note that when metal cools and solidifies it shrinks a few percent (called the "percent shrink"). Therefore the wax preforms made in the aluminum mold are actually that percentage oversize from the desired finish size of the casting.
Ed Weldon
04/25/2011 9:10 AM
Thanks buddy...but u went more far...i m jst thinkin of replacing that aluminum die with any other metal or plastic or in short any other material...So wht do u think it's possible...?
Good Answers: 183
04/25/2011 10:48 AM
Your message is a mail or a sms? If it is a mail please make the effort to write in plain english and not in the gibberish used for cellular phones.
It is a question of respect for the reader.
Good Answers: 196
04/25/2011 12:24 PM
And yes, I agree with Nickname. You are well advised to communicate on these issues in a recognized formal language that can be understood by others and logically translated into English for the benefit of the participants in this forum. If your needs are so trivial that you cannot meet this reasonable requirement then you are hardly worth the time that others would offer to you. And now for the benefit of others who may view this topic and even you if you can understand what is written I offer the following:
The short answer (to "What materials can be used for investment casting dies?") is just about any material that can be molded around a master pattern or machined, carved or whatever to the shape you want. Of course the mold material will have to withstand the temperature of the melted wax without losing its shape. And the wax mold will have to be durable enough to withstand as much use as required for the intended production volume. This is a factor that favors aluminum over silicone rubber, a common wax mold material. Best you learn a lot more about this process and seek out the professional advice of someone with whom you are willing to discuss the specifics of your particular needs.
The long answer can be found at this web site (among others):
Cranston Casting Co. http://www.cranstoncasting.com/Process.htm
44 Worthington Road . Cranston, RI 02920 . Email: info@cranstoncasting.com
phone: 401-467-8184 . fax: 401-467-CAST
The Lost Wax Casting Process dates back to early Egypt and later in China during the Chang Dynasty, 1776-1122 BC. The Lost Wax Casting Process was used mainly to reproduce metal parts and to reduce the time and labor needed for producing parts in quantity by metal smiths. Molten metal was poured into molds and removed when solidified. Since then modern technology has made the metal smith basically extinct.
The Lost Wax Casting Process has basically five steps to produce a raw casting. A craft process, all the steps in the Lost Wax Casting Process are equally important. Today's technology enables us to mold, wax, and cast a smoother, more intricate and complex part, with more precision than ever before
Model:
A model is a metal pattern of the design to be reproduced. It is made 5% larger than the finished casting product. A hard metal is used to withstand the temperatures required for vulcanizing molds. There are many ways to create a model. The customer can realize a significant cost saving and insure a quality casting by consulting with an experienced caster who is aware of current advancements and methods of production. Common modifications may involve undercuts, shrinkage, thickness/thinness, and temperature uniformity.
Molding:
Most molds consist of two parts which create a negative cavity of the design which will be cast. Wax or plastic is injected into the mold to make a positive copy. Molds are made of various types of rubbers, metals, plastics or plasters. Vulcanized rubber is the most common and is the least expensive. It requires the model to be 5% larger. The mold must be able to withstand a temperature of 350 degrees Fahrenheit. Minimum size rubber mold is 3" long x 2" wide x 1/2" thickness. Maximum size rubber mold is 10" long x 6" wide x 6" thickness.
Waxes:
The Wax pattern is a positive copy of the design to be transferred into metal. The waxes or plastics are produced by injecting material directly into the cavity of the mold. It is recommended however, that samples be made to insure a proper burnout for a clean surface before the beginning production. A minimum thickness of .040 is required for proper fluidity. The maximum wax is 10" long, 5" wide, and 5" thick.
Investment Mold:
The Investment mold is a negative copy of the wax pattern. Investment powder, a form of plaster. is mixed with water, and poured as a liquid directly over the wax pattern to make an exact negative mold of the wax design. There are many types of investments. The right investment depends on the way waxes will be treed and grouped inside the flask and the metal which will be used. Once the investment becomes solid over the waxes, the mold is put into ovens to remove all of the wax and cure the investment.
Casting:
Castings are exact metal copies of the mold or wax chosen to be reproduced. The two most common casting techniques are centrifugal casting and vacuum assist casting. Both processes have special requirements for a quality casting, gating and venting being the most common. As a general rule filigree and thinner pieces are more successfully cast centrifugally and heavier, thicker pieces are produced in a vacuum assist process. Our minimum thickness is .040 and our maximum weight per piece is 10 lbs.
Ed Weldon
Register to Reply 4 comments
Ed Weldon (2); nick name (1); shrey.enr (1)
