Previous in Forum: Can One Add Bolts to the Flange of an I-beam?   Next in Forum: Novel Self-adjusting Bonnet Temperatue Control
9 comments
Gear Types
04/24/2011 11:06 PM
Engineers
there are 3 types of gears
1-contant -mesh gears
2 .synchromesh-gears
3-sliding mesh gears.
can any one guide me the following gears comes under what type
spur gears, helical gear, bevel gears, the planetary gears, worm gears, cycloidal gears
Re: gears types
04/24/2011 11:11 PM
Good Answers: 130
Re: gears types
04/25/2011 1:37 AM
Do you mean;
"in these 3 types of gear boxes
1-constant -mesh
2 .synchro-mesh
3- sliding mesh
Which of these gears are usually used?
spur gears, helical gear, bevel gears, the planetary gears, worm gears, cycloidal gears"
Is that the question? Yes? No?
Re: gears types
04/25/2011 5:16 AM
Yes. To be more specific Constant -mesh gear, will use which gear and if possible the reason for using the specific gear thanks.
Good Answers: 130
Re: gears types
04/25/2011 1:15 PM
Is the gearbox for a car? or a truck? or something else?
Is it large or small horsepower?
It for high torque, or high speed?
Is noise a problem? or must it be quiet?
Re: gears types
04/25/2011 9:59 PM
I am sorry i should have written earlier that i need to know that bevel, helical, spur etc, they come under what type of gear i.e 1) sliding mesh gearbox , 2)constant-mesh gearbox, 3)synchromesh gearbox.
the gear box is for different type of machines used in Aluminium film foil plant.
the maximum kw is 800 kw and minimum is 30kw 3 phase induction motors all are Variable speed drives , the maximum speed varies for different motors between 3000 to 1300 rpm
should be quiet.
Good Answers: 130
Re: gears types
04/25/2011 11:11 PM
You seem not to understand these are not 'types of gears'
These are 'gear change methods' - for changing ratios in a multi-ratio gearbox (like a car has)
What you need to do understand what 1), 2), 3) are.
It would be highly unusual to 'change gears' in an industrial process.
Probably a total disaster in a foil rolling process.
Re: gears types
04/26/2011 10:19 PM
Thanks for the reply. No question of replacing the existing system, my interest is just to know about 1) 2) 3). If possible pass the link so that i can go through them thanks
Good Answers: 130
Re: gears types
04/26/2011 10:27 PM
The colored set are the links.
Hover you cursor over them
Re: gears types
04/26/2011 10:52 PM
Thank you once again.I am really grateful to you for increasing my knowledge on gears
Register to Reply 9 comments
34point5 (4); lyn (1); salahuddin zia (4)
You might be interested in: Helical Gears, Metric Gears, Gears
