Previous in Forum: Calculate Motor Winding Turns   Next in Forum: DOL Motors and Long Cable Lengths
Asynchronous Motor with Slip Ring Rotor
04/25/2011 12:13 AM
Hi,
Please answer me very soon, thank you.
We have an old type of Siemens Asynchronous motor and now we recived an offer with same Power & Voltage, But:
Rated speed new is 992, old is 995
Rotor Voltage new 1670 old 1820
rotor current new is 670 old 580
Can we use it with no problem??
Have any way to increase speed of old to new?
Regards
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Re: Asynchronous motor with slip ring rotor
04/25/2011 3:11 AM
The first question is to ensure with the supplier of those motors if their quoted motor is suitable to the existing application and how it would get along with that.
Gurus here will explain you some useful tips. But in order to have that, the information provided by the OP should be very clear.
If you want to increase speed from 992___ to 995___. Please consider what you will achieve if you have 3__ increased by the existing one. If it does nothing to help, why we need to change?
Anything that can go wrong, will go wrong
Good Answers: 181
04/25/2011 3:28 AM
As hien-nguyenquoc said we need more information.
992 as against 995 RPM, but at what loading for each speed?
The rotor controller would be my main concern, what type is it?
Good Answers: 170
04/25/2011 7:03 AM
Don't bother! it will work fine! There wouldn't be proportionate gain vis-a-vis the investments you are going to make for increasing the speed by just 3 RPM. So, don't waste money.
Re: Asynchronous Motor with Slip Ring Rotor
04/26/2011 8:41 AM
Assuming I understood the kind of motor you are havinG:
- Asynchronous with a wound rotor.
- The rotor has slip rings connected to a set of 3 starting resistors (3 phase motor).
- You are using a suuply of 50 Hz and the motor has 3 pairs of poles (6 poles) meaning that its synchronous speed is 1000 rpm
- If the above is what you are talking about, then you have no problems from the running speed difference. This speed is indicated as the full load droop speed.
- Also, as long as the input voltages and frequency are the same, the the rotor values are to insure that the contactors used are adequate for the new motor.
04/26/2011 11:25 AM
NO PROBLEM AT ALL -Go ahead Buy,Install,Run it as you did with the old one.MM
04/27/2011 12:18 PM
Why do you want to go for the same old type of non standard motor? You can use a standard squirrel cage motor with a VFD to obtain similar features. Of course, the cost aspect must be looked into if it is that critical.
Register to Reply 6 comments
electricalexpert65 (1); hien.nguyenquoc (1); LAA_Lucke (1); MUKULMAHANT (1); Priyadarshan (1); TonyS (1)
