Previous in Forum: Fail Safe Sirens   Next in Forum: Fibre Optic Cables & VSAT
20 comments
Beehive Heater
04/25/2011 7:24 AM
Next winter I want to keep the temperature of a beehive Two 8 frame medium hive bodies to around 40 degrees , I have seen where a person used two 7 watt bulbs to do this but they have to be covered so the light doesn't shine in the hive and they burn out and can break . Is there a resistor that will put out about the same heat , I may try heat tape but just wondering about other heat producing items that may work. Thanks for any input .
Re: Beehive heater
04/25/2011 8:37 AM
Re: Is there a resistor that will put out about the same heat
Yes. ;-) What is the voltage of your power source? Assuming you know that you need 14 watts of heat, you can find the needed resistance using R = E^2 (your voltage squared) / P (power in watts).
Assuming that you have a 120 volt power source, you'd need about a 1000 ohm resistor. The resistor would also have to be rated to carry the required power--I'd probably look for one rated at 20 watts.
We used to get things like that (to use as "case heaters" for switchgear installed outdoors) from Chromalox.
However, I have to ask--how accurately must the 40 degree temperature be maintained? Is there a chance of harming the bees if the temperature rises too high?
You may need some sort of temperature control device like a thermostat.
Re: Beehive heater
04/25/2011 10:27 AM
Did you mark this OT, yourself? If not, maybe whoever did mark it can explain their rationale, cause it looks pretty much ON TOPIC to me.
Re: Beehive heater
04/25/2011 11:11 AM
lyn: Thanks for calling that to my attention!
Apparently I did, unintentionally (based on looking at what it says in the ratings--I can't undo it / reverse myself). It's at least the third time I've somehow fat-fingered one of my own comments to be Off-Topic.
Annoying, but who can I be annoyed at except myself. ;-)
I've not marked this Off Topic in hopes of recalling attention to post #1.
Good Answers: 130
Re: Beehive heater
04/25/2011 12:53 PM
1 more help for post #1
Re: Beehive heater
04/25/2011 1:43 PM
Thanks!
Re: Beehive heater
04/26/2011 12:02 PM
Perfect answer. I just pushed it over to a GA for ya. Having had chameleons at one time, I know how expensive things like heat rocks and ceramic heaters with Edison bases cost. A 20W resistor at about 2K ohms will get you a nice 7W at 120V. My only input would be to place it in an screened enclosure so the bees don't burn their little feet.
Re: Beehive heater
04/26/2011 1:51 PM
Thanks! :-)
Re: Beehive Heater
04/25/2011 8:59 AM
Dear,
You may use a step down isolating Transformer for bulbs, say 220V /190 V, then bulbs will not burn out for years.
- Or else, you may create a heater panel with termostate,
You may use 10W * 3 heaters - 240V, connected in star, with termo state put in bee hive. you will gat constant temp. band width of about 5 to 7 degrees.
You may set thermo state at say 35 deg. , then, you will get temp. band between 35 deg. and 40 deg.
Exploring the Science of Electricity
Re: Beehive Heater
04/25/2011 11:25 AM
Try using a ceramic heater bulb like they use for reptile tanks. They put off heat but not light and they last a long time. You can pick one up at any good pet supply store.
“If you forget you have to struggle for improvement you go backward.”
Good Answers: 804
Re: Beehive Heater
04/25/2011 2:46 PM
When selecting any kind of heat source where humans (or animals like bees) are going to potentially be in proximity, you have to consider what's called the "watt density" in order to maintain a margin of safety to the touch. So although a resistor will put out the same amount of heat as a "heater" of similar wattage, the device designed as a heater will have a lower watt density and thus not be red hot when in normal operation. That's what you pay extra for in a space heater compared to a resistor. In general, that's another reason why people use light bulbs as heat sources, but to be honest the only way you keep the watt density low is to use multiple low wattage bulbs that are as large as possible, and that often ends up costing more than just buying a proper heater.
Re: Beehive Heater
04/25/2011 3:23 PM
At pet stores, you can get heated "rocks" used for reptile cages. They aren't all that expensive, and it sounds like around the capacity that you need.
http://www.freshmarine.com/zoomed-heat-rock-stan.html
Just an example.
Re: Beehive Heater
04/26/2011 7:58 AM
That's pretty much what I said in post number 5. A ceramic heat bulb for reptiles that screws into a light socket you can pick up at most pet stores cheap. They warm up nice and they would keep the hives in the range op mentioned. Heat rocks warm up a little but they really don't radiate much heat. I've used both in my tanks with my red tail boas, leopard gecko and my iguanas and the rocks alone will not warm the tanks up, they have to lay directly on them to warm up their bodies. The ceramic bulb works great though. You can even hook them up to a thermostat to keep whatever your warming up at a certain constant temperature. These bulbs also do not emit any light as mentioned in post number 5.
Re: Beehive Heater
04/25/2011 6:39 PM
Thank you all , the heat rocks sound like the answer I will check into them. Bees !!!
Re: Beehive Heater
04/26/2011 8:55 AM
Yes there are resistor materials prefabricated are there in market. Only issue is which part of the world you are so based on your supply voltage you can select one. If you do not find one which you like then you can make one by yourself and if you need help let me know and I will guide you
Masyood
Re: Beehive Heater
04/26/2011 9:09 AM
They also make heat pads for pet nesting boxes, such as rabbits. Check that out too.
Re: Beehive Heater
04/26/2011 12:13 PM
You might try wiring two 30 w bulbs in series. Each would see only half the voltage and the lifetime would be greatly extended.
Good Answers: 153
Re: Beehive Heater
04/26/2011 1:37 PM
Why not use a PTC heater. This is a self regulating heater that increases resistance dramatically when the 40 degrees is reached. The current and thus power is restricted and the set temperature is maintained. No light, no burning, high reliability, economic to run.
Check out the web for suppliers in your area.
Re: Beehive Heater
04/28/2011 2:14 PM
This is such a great example how valuable CR4 can be! It's also a great example of the wonderful creativity of posters here. Kudos to all.
Re: Beehive Heater
04/28/2011 5:05 PM
Elevate the hive on a pair of cinder blocks and attach a box below the bottom board to house the lamps. BTW My honeybees have survived quite well an New England winters with no heat what-so-ever. Just be sure they have plenty of sugar water in the feeder.
Re: Beehive Heater
04/28/2011 6:05 PM
I found heat tape called Flex Watt I am looking into that ,for reptiles . Thanks everybody for your comments . Brian
Register to Reply 20 comments
34point5 (1); Anonymous Poster (1); Brave Sir Robin (1); Gazu (1); harry potter (1); jhhassociates (1); JRaef (1); lyn (1); Masyood (1); Mikerho (1); mrclean (2); naturaledge (2); rhkramer (4); Rixter (1); Tom_Consulting (1)
