Previous in Forum: Well Pump Failure   Next in Forum: How Many Times Can You Repair A Pressure Vessel Safely
Discharge Piping Velocity
04/25/2011 3:22 PM
Dears
Why there is a limitation for the discharge piping velocity in a centrifugal pump to be between 4.5 t0 0.9 m/s and if the velocity exceed the limit to be over or less than this limit what will be happend
Re: Discharge piping velocity
04/25/2011 3:31 PM
Friction loss increases, load on motor increases.
Re: Discharge Piping Velocity
04/25/2011 11:36 PM
If there is grit in the pumpage, velocities > 2 m/s or so may lead to erosion of the piping. High velocities → high pipe friction losses → higher required pump head → higher pumping costs.
04/26/2011 1:20 AM
Thanks for reply,Ok if there is no check valve on the discharge piping and the flow going firstly by the recycle piping to the Tank on a velocity 8m/s in 4"pipe then open the main line with a 35m3/hr on 10"pipe that mean the velocity will be around 0.192 m/s and close the recyle line block valve is any possibility for back pressure,water hammer?
04/26/2011 2:14 AM
I'm not sure about these numbers.
8 m/s in 4" (100mm) pipe ≈ 226 m3/h. (This is a very high velocity.)
For 35 m3/h in 10" (250mm) pipe, I get ~0.198 m/s velocity, which is close to your number. (But this is a very low velocity.)
What is the m3/h actually supposed to be?
If valves are opened/closed slowly, water hammer should not be a problem.
04/26/2011 3:07 AM
The rated velocity is 1480rpm,so it will be about 7.8 m/s ,but frankly i am not sure this the velocity, but as per operation procedure it suppose to start with 10HZ up to 50 HZ(1480 RPM ) I don't think they follow the correct procedure since after open the main line and closing the recycle the flow 35 m3/hr almost 30% of the rated flow 120m3/hr ,this pump shut down and scratch mark and pitting found in the impeller
04/26/2011 4:40 AM
Well, these things always bring trouble so while connecting to it make sure use rubber hand.
Register to Reply 6 comments
anneparker (1); elsheikh (2); lyn (1); Tornado (2)
