If the light is working, and you have a rooster, he'll start crowing when the on/off discriminator is positioned in the "on" position and exposed to the visible light spectrum of the bulb under test. The rooster will need a rest between cycles to reset his internal mechanisms. Repeat as necessary. Btw, if the rooster does not crow, you can assume the bulb is defective, or the rooster is. Either way, it's a good test for bulbs and roosters. Maybe you just need a new rooster.
