Hi! all,
May I seek the help of experienced instrument engineer/technician. In our plant, we have yokogawa pressure transmitter and set from -0.15 to + 0.15 Kg/cm2.
The problem is very high indication. it reached 110% and display error. We tried to set to zero manually using the screw adjustment at the bottom portion of the housing but later on it rises again and reached 110%.
What might be the cause of this over range?
I hope can anybody will give clear suggestions. We are new in this field that is why we do trial and error.
Thank you very much.
New I&C tech.
