Previous in Forum: Yokogawa Pressure Transmitter   Next in Forum: Selection Criteria for Flow-to-Open and Flow-to-Close Control Valve
I Need a Signal Converter That Can Give Me 0 to 200mA Out For 0 to 20mA In
04/27/2011 6:29 PM
I need to interface a piece of equipment that has an output capable of a maximum range of 0 to 24 mA to an actuator that requires 20 to 160 mA nominal input. I have only found one manufacturer of such a device and know there are bound to be more somewhere. I have 24~28 VDC available to power the signal converter. DIN rail mounting is preferred.
I don't want to know how to build one. I don't want to have a custom built assembly made. I just want to be able to buy a few of them off the shelf from a reputable manufacturer somewhere.
If I have to flip a few switches, move a few jumpers to set ranges and or adjust a pot or four, that is not a problem.
Any suggestions?
Thanks!
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
Good Answers: 141
Re: I Need a Signal Converter That Can Give Me 0 to 200mA Out For 0 to 20mA In
04/27/2011 10:51 PM
I do not know of a right from the shelf make, but if you know the load where to dump
the current in you can go with a average 10 time current amplifier. Depending on your application: a DC or AC direct coupled amplifier.
One power transistor and a few components could do the job.
Plenty of room here
04/28/2011 5:57 PM
I may have something here at Instrumart but I need to know the input signal type.
http://www.axiomatic.com/current-converter.pdf
Thanks,
Dwight
Phone number removed - CR4 Admin
04/28/2011 6:07 PM
Tried to call but apparently you were already gone.
The AXIOMATIC is the one I found myself but I will be happy to talk to you to see what you have in mind.
Have FUN!
TT3
Good Answers: 32
04/28/2011 11:16 PM
You have one critical parameter "Load definition" missing in your catalogs. Without defining Load, meaning of current is incomplete. Perhaps 24V/200mA = 120 Ohms looks like the maximum load for 200mA signal. Perhaps you can fix it at 100 ohms maximum in your catalogs to permit some room for 24V supply. Industrial supplies are often 10V to 30V range anything. Hence for industrial power range it should be defined only 50 ohms maximum.
If you have a regulated DC-DC converter inside your current converters then perhaps you can define as per your own specifications.
Look at how Datasoft have defined their catalogs and perhaps you can get some good idea there. www.datasoft.com/
Register to Reply 4 comments
dvmdsc (1); instrumartgirl (1); Shyam (1); Turbotroll3 (1)
