Previous in Forum: Metal Grit Recovery   Next in Forum: Casting Tolerance
Agitator's Baffle Size
04/27/2011 6:24 AM
Dear Sirs,
We produce a vessel containing sugar sub-product with density 1,5kg/m3.
The vessel is vertical with inlet diameter 4mtr and height 9mtr
On the roof of the vessel there is an agitator for the increace of turbulence with 43RPM and 5.5kW.
Along the vessel there are 2 baffles with dimensions WxLxthick (320mm x 8000mm x 8mm) in order to induce the vorticity. Baffles are positioned 1.0m from the wall of the vessel (vertically positioned)
Can you advise for a calculation method and a typical design concerning the supports of these baffles?
Your prompt reply is highly appreciated.
Re: Agitator's Baffle Size
04/27/2011 10:22 PM
Sorry I don't have an answer to your question but is the density actually
"one point five kilograms per cubic meter"
as you seem to have written? That's pretty light.
Are we talking about carbon dioxide gas?
Logic is the art of going wrong with confidence. -- Morris Kline
04/28/2011 2:16 AM
Dear Sir,
Thanks for your interest. Erroneously was written the density 1,5kg/m3 the actual density is 1500kg/m3 and it concerns liquid raw material for sugar.
Apologize for any inconvenience caused.
Regards
Giannis
Good Answers: 137
04/28/2011 6:25 AM
I doubt whether the force on the baffles is significant. If you make supports that look something like right in relation to the baffle size I don't think you'll go far wrong.
I'd suggest 50 x 50 x 8mm thick RSAs welded to the vessel wall. 8 off RSAs per bafflle, one 0.5m from each end, the others at 1m spacing in between.
Cheers.........Codey
Register to Reply 3 comments
Codemaster (1); GordieGii (1); gvallios (1)
