Hi guys, this is a doubt that i could not get clarified thru ETAP's manuals.
during the MOTOR STARTING ANALYSIS, can we view the currents/voltages at the terminals of other running loads if one of the motor is started using the time slider ?? Usually we only see the current and voltage drop at that particular motor alone using time slider. Is my requirement achievable using ETAP ??
I have 4 nos . of identical 132kV/6.6kV transformer each sourced individually from the power grid that i have modeled..The loads are connected downstream to the transformer. each of the transformer is connected to a 6.6kV bus with bus -tie bet. each of the 4 buses. the buses are having their own IM and synchronous motor loads.
My aim is to start one 6400HP synchronous motor connected to the load and see what the voltage drop is like and whether is it possible to start using only 2 transformers. i m able to view the results. but the other requirement for me is as started in the beginning .. is it possible to see the effect of this motor starting on the other connected motors/loads at the same time ?
thanks in advance
cheers!
siddharth
