Previous in Forum: Cavitation in Centrifugal Pump   Next in Forum: Turbo Expander Bearing Gas Problem
Equ Moment of Inertia
04/27/2011 10:25 AM
Hi,
I have DC motor coupled with gear box contains Spur gear (1:2) , worm gear (1:36) and Sun and three planetary gears (1:4) connected in series with shaft. The total GR is (1:288).
Please let me know how to calculate equivalent moment of inertia for the system.
Thanks and Regards,
Senthil G
Good Answers: 181
Re: Equ moment of inertia
04/27/2011 10:36 AM
Homework?
Or was the designer of the gearbox drunk?
Good Answers: 21
Re: Equ Moment of Inertia
04/27/2011 1:54 PM
Got a picture of this gear box you can post. Something is not quite right in the description you gave. Also a manufactures model number.
Good Answers: 137
04/28/2011 6:39 AM
Referred to motor speed, the moment of inertia of each rotating part is its own MoI divided by r2, where r = speed ratio (r > 1 for a reducing gearbox). So you need to know the MoI of each part. The total MoI is the sum of all the parts.
But you haven't mentioned the load (running at 1/288 of motor speed). This is usually a bigger contribution to the total MoI than the gearbox, but is calculated the same way.
Cheers.........Codey
Register to Reply 3 comments
Codemaster (1); fixitorelse (1); TonyS (1)
