Good day all.
I have a 3 house town house, of which I want to control the AC flow.
So this is home work. (home automation)
The first floor has each one return duct and one feed.
3 returns in total and 3 feeds - the ducts are 18" styrofoam and have butterfly valves, that can open with 90 degrees.
There is a distribution box with 3 channels in it.
The second floor has 28 individual outlets for the rooms, each separately damped in the attic. The airbox has 4 butterfly valves: 3 of 16" and one for the attic ring duct
of 24".
Per room I need a temperature control, a proximity system (to detect if there are people or not) and a door switch And Window switch that closes the damper if open. (same for no people detection)
The dampers have all a 6" span (between open and close)
The butterly valves can operate the same way.
Nothing is on it yet: I operate it manually which makes me do a lot of trips to the attic and garage, where the technical room is situated.
Besides this - since I operate the whole house combination with only one 5 ton
unit - Styro house, thermal doors and triple glass.
I have been looking to as much wireless and digital as possible.
Any of you engineers have experience with this?
Need hints for materials to automate this.
Thank you for any help.
