Previous in Forum: Superior Bending Machine   Next in Forum: Industrial Boiler
Quest for Large Diameter Special Hoses
04/29/2011 9:14 AM
I am in the need for 6",8",10" 12" Hard Wall Suction Hose in lengths of 200 Plus Feet each section. Pressure rated at 400 PSI, Tensile Strength of 12,000 lbs vertical. Service is Seawater inside & out. Must have UV & Ozone protection. Approved Certifications from ABS, DNV, & GL is a Must. Must have Flame Test Approvals For Fire Water Service. Must have tight bend radius. My service is for offshore Vessels.
I have found small companies willing to manufacture it to these specs, but I have to pay for all the tooling and outside testing requirements. I need hoses that will have all this in place, approvals already done. Any Help in locating these would be greatly appreciated.
Pathfinder Tags: Special Hoses
Good Answers: 1693
Re: Quest for Large Diameter Special Hoses
04/29/2011 10:21 AM
05/02/2011 8:50 AM
Thanks LYN,
So far, Your right On.
I haven't found any other than special made as I'm currently doing. It's just my supplier is limited to 200 ft.
BJG
04/29/2011 2:03 PM
All I can think of that might meet the specs is the stuff they use on oil rigs. I googled oil rig hoses.
http://www.worldrigsupply.com/
Good Answers: 150
05/01/2011 12:01 PM
talk to Tecnip-Coflexip. they have something up to 6" available. perhaps larger in different designs.
http://www.technip.com/draps/onshore/pdf/coflexlite.pdf
http://www.technip.com/draps/whoarewe/frame2.html
Who is John Galt?
05/02/2011 8:48 AM
Thanks Kramarat.
The Oilfield is the market I'm in. Most of the hoses made for the oil rigs such as Kill & Chock hose will work but are nut made in the lengths and sizes I need.
Thanks for the input.
BJG
05/02/2011 9:00 AM
I wonder if dredge hose would work? Maybe worth a few calls.
http://www.salem-republic.com/dredge-hose.htm
Register to Reply 6 comments
BGuillot (2); kramarat (2); lyn (1); Rorschach (1)
