Previous in Forum: Combined WPS   Next in Forum: Stiffener Plate
Ultrasonic Test
05/02/2011 1:58 PM
can any one answer the following questions?
1- You are required to scan the full volume of an unground tee joint weld on 100mm thick plate. Scanning is to be done from one side of the weld prep plate using a 45ø probe. What is the scan distance you must move from the tee plate surface to ensure 100%.
is the answer is 230mm or not and why?
2- You are to scan an unground 50mm thick butt weld from one side of the weld only. The plate is 20mm thick and full volumetric coverage of the weld plus 20mm heat affected zone is needed. Weld face is 20mm wide. What is the maximum scan distance from the weld center?
is the answer is 98mm or not and why?
Ask right person to get the right answer.
Pathfinder Tags: Ultrasonic test
Re: Ultrasonic Test
05/11/2011 5:48 AM
Make a drawing on Autocad. Draw Lines at 45 degrees identifying the scannning wave and the distance between them will be the scan distance.
