Previous in Forum: Need HELP Transferring Data from Smith Corona PWP to CD   Next in Forum: How to Protect My WD External USB2 HDD?
13 comments
System Image Occupying Large Memory In My PC
05/03/2011 10:56 PM
kindly help me, my computer is running using window 7.
I'm having problem with my memory, because system image occuying more than 90GB.
how can fix this problem?
thank you.
United States - US - Statue of Liberty - Who is John Galt?
Re: system image occupying large memory in my PC
05/04/2011 12:54 AM
I'm not using Windows 7, still using XP Pro. But I do remember seeing something about a sparse memory matrix and sparse files being significantly improves in 7. Chances are you have nothing to worry about... but if someone knows better I'm all ears.
I'd've written a shorter post, but I didn't have the time.
05/04/2011 11:19 PM
I'm no expert, but if something was occupying 90Gb of my memory, I think I would be worried.
05/05/2011 10:09 AM
I tend to agree... that said Windoze is 'occupying' a large slice of real estate that would be far better utilized with a _real_ OS like... say... linux... ;^) just say'in.
Honestly, I had a hard time reconciling the question with any reasonable answer; 90Gb simply doesn't make sense unless it's a backup of his whole system; then the nature of the complaint becomes suspicious.
Sometimes I miss the old days with DOS 5.0, Lantastic, AILANBIO, and my TallGrass DC6250 tapes... just say'in ;^)
Re: System Image Occupying Large Memory In My PC
05/04/2011 11:14 PM
i am not a professional .may be you can compress your images
05/05/2011 1:17 AM
Hi
1 - open control panel
2 - click on backup and restore icon
3 - find word backup, and under it click manage backup.
4 - if user accoun control account pop up, click yes.
5 - select the backup location in the window you are seeing.(that is place on your harddrive).
6 - click on view backup button. (a list of backups is there, order is recent to old)
7 - select one of old backups you want to delete. (If list is long, select now the oldest)
8 - press the button delete.
Repeat steps 7 and 8 for all "old backups".
Keep only the current backup(see the date). Do not delete it.
Thats it.
Have fun.
05/05/2011 1:25 AM
thank you wahaj87, actually I did your already your advise. but the system image still in 90GB.
Good Answers: 19
05/05/2011 2:23 AM
Did you remember to empty the Recycle Bin?
05/05/2011 2:31 AM
recycle bin already empty
Good Answers: 19
05/05/2011 2:53 AM
Here are easy-to-understand instructions from another source:
http://www.howtogeek.com/howto/4241/how-to-create-a-system-image-in-windows-7/
Maybe you should go back and start over from the beginning. Good luck!
05/05/2011 3:09 AM
i think it will help.
Thanks a lot.
God bless
05/05/2011 8:22 AM
Hi,
I don't know if this will help: Windows might be reserving that space for the system (backups &/or normal operation) and it could be that this value can be tuned down if required, but normally Windows recommends and automatically reserves that space.
At least it used to do this in previous versions. Windows 7 may still be the same since it needs a lot of memory (Virtual ) to supplement the RAM on the PC (???)
05/15/2011 4:36 PM
Dood, a system image is like a picture of your computer which can be used to restore your computer if anything untoward happens to it. Usually its a bit pointless having it on your computers hard drive cause chances are if your computer gets messed you'll lose that along with everything else. What I do is have the system image, alongside a backup of all the hard drive files on a portable hard drive (Seagate 500GB). That way you can restore your entire computer files and settings if your hard drive needs to be formatted or if it fails epicly whatever
Hope that helped
Good Answers: 97
05/18/2011 11:04 PM
Run the following command "net user administrator /active:no" ********* Or************** run the "sysprep /generalize" command next time the computer starts, the built-in Administrator account will be disabled.************** Someone got sloppy after configuration and didn't delete it.*********** Consult: http://social.technet.microsoft.com/Search/en-US?query=restrict%20system%20image&refinement=1002&beta=0&ac=8
Register to Reply 13 comments
bubbapebi (2); bwire (1); Drewsberry (1); jackmold (1); LAA_Lucke (1); nonoy (3); Olebogile (1); tick-tock (2); wahaj87 (1)
