Previous in Forum: Odd Corrugation Change   Next in Forum: Peek Material Having Burrs After Drilling of a Size .018mm
Carbon Dioxide Handling
05/04/2011 6:41 AM
Hi
We have following flow diagram
Battery of CO2 Cylinders ---- Header ----- Heater at 65 deg C ------Pressure reducing valve from 70 bar to 10 bar (No. 1 ) ------safety valve ------ pressure reducing valve from 10 bar to 1.5 bar (No. 2) -------safety valve --------ball valve ---- flow meter -----to process tank.
The problem is that after some time of starting the process the flow rates are achieved upto 25 kg/hr but after that the pressure reduces to less than 2 bar at PRV no. 1 and flow rate reduces to almost 0. we are unable to understand why flow is stopping in between.
Regards
Munish Prashar
Pathfinder Tags: carbon dioxide
Good Answers: 266
Re: Carbon Dioxide handling
05/04/2011 7:03 AM
The regulation valve maybe freezing up. What's it temperature? And is it rated to operate at that temperature?
05/04/2011 7:15 AM
It looks like the Joule-Thompson expansion effect is getting in the way.
Increase the heater outlet temperature.
Re: Carbon Dioxide Handling
05/04/2011 8:04 PM
Is the heater correctly rated - i.e. is it capable of heating the CO2 to 65° at that flow rate? Have you done the sums? Does it work consistently at lower flow rates?
Try running it and going over the system with a hot air gun (a hair dryer will do at a pinch) to see whether extra heating is needed anywhere.
05/05/2011 1:40 AM
Thanks for your inputs , we have heated the PRV 1 and also bypassed it by controlling needle valve provided for fixing pressure gauges , now the flow is coming from bypass line as welll as little flow from PRV1 till the time we replace the PRV 1
Register to Reply 4 comments
JohnDG (1); munish_prashar (1); ozzb (1); PWSlack (1)
