Previous in Forum: How to Protect My WD External USB2 HDD?   Next in Forum: OCZ "Vertex Series" SATA II 2.5" Solid State Drive
Good Answers: 12
Excell 97 Help - Paper Clip no Help
05/04/2011 9:46 PM
Hi again... This time I have an Excell 97 question where the Help Paper Clip is no help...I want to do a search (find) a string of characters or a part number within my spreadsheet that has some 20+ sheets. The Ctrl F only searches the active sheet. I found a shorter way (using Sft-F4) and opening every sheet. There does not seem to be a find method across multiple sheets. I tried highlighting the sheets and doing a search - yes it jumps to one sheet but as I try hit enter to find other instances, it remains on the one sheet. Thanks in advance.
Re: Excell 97 Help - Paper Clip no Help
05/04/2011 10:44 PM
Well under Excel 2003 you can perform a search using ctrl F, expand the 'options' box and choose the 'within' box and set it to 'workbook' which will search all sheets in an open workbook.
Excel 97 should work the same (hopefully).
Good Answers: 12
05/05/2011 12:03 AM
No...97 does not have this. Ctrl F only has Search by row/column and Look in Formulas/values/comments...and two tick boxes: match case and find entire cells only.
Re: Excel 97 Help - Paper Clip no Help
05/06/2011 12:10 AM
You could always write a macro and do it that way. My code writing skills are not current enough to give you the detail, but if you learn by recording a couple of macro's and by reading web pages that relate to something like "Excel Macro searching multiple sheets for values" you should manage to generate a solution in a few hours.
05/06/2011 8:27 AM
Hi: you can do "CTRL+ Click" in each sheet you want to search and then "CTRL+F".
Gabriel
Gabriel, Buenos Aires, Argentina
05/06/2011 8:32 AM
I have found this website very helpful with all excel questions. www.ozgrid.com They have experts that will help when you post questions just like CR4 does only it deals exclusively with excel problems.
05/06/2011 10:23 PM
The oldest version I have to test against is Excel2000 -- and here's how I was able to do a search across multiple sheets:
Before you start your search:
  • click on the first sheet (the tabs along the bottom)
  • hold down SHIFT and click on the last sheet
Now start your search. (You instead could hold the Ctrl key and click on each sheet that you wish to search through instead before your search)
Definitely worked in Excel 2000 and did jump from sheet to sheet.
Register to Reply 6 comments
cb50chevy (1); daffy (1); Gabriel (1); jack of all trades (1); robbump (1); TrevorM (1)
