Previous in Forum: Excell 97 Help - Paper Clip no Help   Next in Forum: Programing Link is Needed!
OCZ "Vertex Series" SATA II 2.5" Solid State Drive
05/04/2011 10:41 PM
Hi, I have a OCZ "Vertex Series" SATA II 2.5" Solid State Drive. After attaching it to a Linksys 610N router. I formated it via the advanced mode thru the router. I wanted to add this drive to the router as additional storage to aid in media downloading, Viewing, and Sharing. I belive it was formatted in a FAT32 Mode. Ever since that format no computer can recognize this Drive! Please can anyone help or suggest how to get around this type of drive Problem?
Thank You, Sincerely
Mark N 05/04/2011
Re: OCZ "Vertex Series" SATA II 2.5" Solid State Drive
05/04/2011 10:52 PM
I found some helpful advice here
http://reviews.cnet.com/routers/linksys-wrt610n-simultaneous-dual/4852-3319_7-33132573.html
A firmware update is also mentioned (and highly recommended).
05/04/2011 11:05 PM
I'm not very computer savvy. I'd liken this problem to someone who buys a '92 Ford transmission for his '95 Chevy truck.
They both have four speeds, but the mounting holes, dimensions, shaft diameters and spline counts are unknown. They are not the same, but nobody can say for sure how to hook them up. So, you spend days doing the research that should have been done before the sale was made.
Maybe it works, maybe it doesn't. But the guy who sells it to you can just shrug his shoulders and say, "It's not my fault, the transmission has an input shaft and an output shaft. It's up to you to hook 'em up and make 'em work."
Bill Gates is rich beyond your wildest dreams because he found a way to sell half developed software to fools who would de-bug it for free.
05/04/2011 11:11 PM
It is fortunate that most technical products have good tech support groups, by that I mean customers who have figured out what works and doesn't work through trial and error.
05/05/2011 11:23 PM
Never ever format a SSHDD under any conditions. It is not a physical drive, they are memory chips and do not need to be formatted. Erasing/deleting is the only way to clean unwated uneeded data. Formatting must never be done.
"Real Bass Players" do not use picks
05/06/2011 9:38 AM
I'm afraid you are mistaken. Every storage system of every construction needs to be formatted (and optionally partitioned) and the same is true of solid state drives, see
http://images.crucial.com/pdf/crucial_ssd_formatting-partitioning_v1.0_english.pdf
It is worth noting that USB thumb drives also need to be formatted, but that is almost always done before they are sold.
Unfortunately the OP has not clearly stated his problem. If, after formatting the drive, he has removed the drive from the router and attached it to a computer, then it should be visible on that computer; otherwise there is a fault with the formatting or with the drive itself. However, if the drive has been left in place on the router, it is there to serve only as a buffer on the router, and there is absolutely no reason why it should be visible to any computer on the network. A non-problem, in fact.
Location: Ground Zero of the Pompous and self important....Washington DC
05/06/2011 2:00 PM
Yes....you CAN reformat a SSD, I have several machines using them as boot drives.
What you don't want to do is defrag them. and in Windows 7 you don't have to as the OS uses the TRIM command that is far more SSD friendly and won't shorten its life.
jack of all trades (2); Jimh77 (1); lyn (1); phph001 (1); Smoothy (1)
