Previous in Forum: Thermal Actuators   Next in Forum: CDM-Clean Development Mechanism
Wall Thickness
05/05/2011 6:32 AM
Hi
I need to know the methodology to calulate the wall thickness with tolerance for carbon steel pipe as per as ASME 31.8 and API 5 L 44 Edition 2007.
regards
Pathfinder Tags: wall thickness
Re: wall thickness
05/05/2011 6:54 AM
A useful check is to carry out a force balance calculation along a theoretical section down a diameter. Repeat with a theoretical section across the diameter, and take the larger thickness figure as the minimum.
Good Answers: 61
Re: Wall Thickness
05/05/2011 6:36 PM
Go here and check out this:
http://www.pipingengineer.com/online/pipewallcalc.html
Do it once and do it right
Register to Reply 2 comments
You might be interested in: Thickness Gages, Control Valves, Clarifiers
