Previous in Forum: Sprinkler Head   Next in Forum: CK15
Bearing Size
05/06/2011 4:23 AM
i need to buy a bearing for an electric motor. i don't have a part number, but the
shaft measures .591 and it's a press fit. what should the id of the bearing be?
Good Answers: 130
Re: bearing size
05/06/2011 6:07 AM
15 mm
Re: Bearing Size
05/06/2011 5:42 PM
I wonder what the outer dimension for the bearing will be? Possibly 0.0201 cubits?
Hobbies - CNC - New Member Engineering Fields - Mechanical Engineering - New Member
Re: Bearing Size
05/06/2011 10:39 PM
Try this.... www.superiorbearings.com. My cubit calculator is out of order, but that sounds close, too.
Re: Bearing Size
05/06/2011 10:47 PM
Whoops! I left part of it off... Try this....www.superiorbearings.com/standard_size_automotive_bearings.htm.
Re: Bearing Size
05/06/2011 10:55 PM
What you need is an x03 bearing.The value of X depends on the outer dimension of the bearing.It could be a 203, a 303, or a 403 ,etc.The last 2 digits usually signify the shaft size in MM/5.That is, multiply the last 2 digits by 5 and you will get the inside dimension of the bearing and the shaft size for a press fit.The first number signifies the ball diameter, so a 304 bearing is larger on the outside bore, but the same inside bore as a 203 bearing.There are many suffixes to designate other variables,such a shielded,sealed, open face, etc.but the best reference is a good bearing catalog or google search for any major bearing company.
If this is a fractional HP motor, you probably need a 203 KDD, or NPP bearing.
Good luck
Re: Bearing Size
05/06/2011 11:24 PM
6203,6303,6403 depending on what the OD seat in housing is.
Register to Reply 6 comments
34point5 (1); HiTekRedNek (1); MUKULMAHANT (1); redfred (1); the wrench (2)
