Previous in Forum: Vacuum Vessel Level Measurement   Next in Forum: Orifice Straight Run Requirements
Marshelling Panel
05/07/2011 8:36 AM
Hi friends, good evening to all. i want know the function of the marshelling panel inside the control room. so anybody can describe the function and uses of the marshelling panel. Expecting your valuable answers, thanks & regrds
Re: Marshelling Panel
05/07/2011 12:19 PM
Did you try a search before coming here?
Marshalling Panel - Pyrotech Electronics
05/07/2011 3:31 PM
historically, the term comes railroad marshalling yards:
http://cr4.globalspec.com/thread/52087/Marshalling-Cabinet
Good Answers: 18
05/08/2011 3:21 AM
Good answer Carl_E (like your previous posting in answer to this question).
According to the 'Concise Oxford Dictionary' the word Marshal when used as a verb would mean 'arrange in due order' or 'take up positions in due arrangement' as in a railway marshalling yard where goods trains are arranged and assembled on arrival or before being dispatched. (your example). Origin French 'Mareshal'
As far as the OP's question goes re the functions and uses of a Marshalling Panel -
Function : To provide one location (e.g. in a control room) where all field wiring may be terminated before being re-routed to their control boards which simplifies the wiring and also makes it easy to inter-connect various control wiring (e.g. interlocks between panels etc.)
Uses : When testing, fault-finding, monitoring, connecting or replacing cabling between the control equipment and the field equipment, a marshalling panel provides one access point which enables one to have access to the control wiring terminations without having to open up a whole lot of different panels.
A little knowledge that acts is worth infinitely more than much knowledge which is idle! Khalil Gibran
06/06/2011 6:41 AM
So, how can we diffrentiate between Junction Box and Marshalling?
could it be possible to send the output cable of JB to the controller (DCS, PLC etc.) directly?
when marshalling panel is needed?
08/15/2011 1:13 AM
If you have a small control system with merely a limited number of inputs and outputs, where you can have just one control cabinet, you may forget about using marshaling cabinet(s) and include termination, auxuliary relays and other components usually placed in a marshaling cabinet, in the main control cabinet itself.
Good Answers: 70
05/08/2011 7:45 PM
This too, sound like another home work question, but at least their asking in away that you have to answer with an essay and not multiple choices. DJ
Carl_E (1); dj95401 (1); Fardan (1); Hasmoz (1); Keith Grewar (1); lyn (1)
