Previous in Forum: Marshelling Panel   Next in Forum: What Is The Use Of Test Terminal On Pressure Tx
Orifice Straight Run Requirements
05/07/2011 6:09 PM
Could someone please tell me how to calculate straight run for orifice with more than 2 fittings preceding it?
As per my intrepretation of ISO 5167-2, when we have 2 fittings preceding the orifice, the straight length req is either the straight length req for fiitting 2 with the beta ratio of the assembly under consideration or the sum of the (staright length for fitting 1 with beta ratio of assembly under consideration) & (1/2*pipe dia between fitting 1 & 2 * straight run for fitting 2 with beta=0.67), which ever one is greater.
But how do I calculate the staright length if have 3 or more fittings preceding the orifice?
In my case I have fitting 1=full bore gate valve, fitting 2=cocentric reducer & fitting 3= equal tee preceding the orifice.
Thanks in advance.
Re: Orifice straight run requiremnts
05/07/2011 6:25 PM
Most of the flowmeter literature I've seen suggests 5d of straight piping before the meter and 10d after. But this is a rule of thumb, and it might not account for large numbers of fittings in either direction. Simple flow-restricting orifices would probably require less.
That ISO 5167-2 beta ratio stuff sounds like too much theory trying to chase too little practical knowledge. What does the orifice or flowmeter manufacturer's literature say?
To be really safe, how about 1 km before and 2 km after?* [The kramarat asterisk indicates facetiousness.]
Re: Orifice Straight Run Requirements
05/09/2011 5:13 AM
If I cannot get the 5d upstream and 10d downstream then I always use a flow straightener before the orifice plate with good results.
A day without a smile is a day lost
05/09/2011 10:42 AM
What is a flow straightener? Is it real, or a joke?
05/09/2011 10:52 AM
I used to buy flow straighteners from ISA Controls, Shildon, County Durham, UK, I think they may be part of the Emerson group now. Its a plate about 30mm thick with holes drilled to a calculated pattern
05/09/2011 11:07 AM
Thank you. The concept is absolutely new to me, but it seems that it just might work. Thank you, again.
05/09/2011 11:17 AM
Try this link, I forgot that they were part of the Solartron group. www.solartronisa.com ,
Register to Reply 6 comments
LinwoodCIII (2); peterd (3); Tornado (1)
