Previous in Forum: Oil Analysis During Standard Oil Change   Next in Forum: How Do You Remove a Seat Belt in a Car?
9 comments
Grease Fittings
05/09/2011 7:07 PM
What kind of grease should I use to lubricate muffler bearings?
Good Answers: 145
Re: Grease Fittings
05/10/2011 3:29 AM
Hi temp asbestos grease. make sure its the smokeless variety..
Good Answers: 44
Re: Grease Fittings
05/10/2011 11:05 AM
elbow grease. make sure you check the headlight fluid, as they are on the same maintenance periodicity.
Re: Grease Fittings
05/10/2011 1:15 PM
The muffler grease zerk can be found under the 710 cap.
It should look something like this. Identification is easy; look for the '710'.
Re: Grease Fittings
05/10/2011 9:13 PM
No, I need the one that's underneath the car, where the muffler is. Not the 710 thingy on top.
I found some doo dads on the wheels that look like grease fittings, but none of them will take grease, and I don't know why every wheel would need one since they are for the exhaust.
Car doesn't stop so good now.
Anonymous Poster #2
Re: Grease Fittings
05/11/2011 9:59 AM
Din'nt anyone ever tell you that greasing the breaks makes the car go faster, and faster, and faster...?
Or was that further?
Re: Grease Fittings
05/11/2011 11:27 AM
Oops. Sorry, the 710 cap gives access to the zerk for the Kneutson valve.
The grease point for the muffler bearing should be near the 'O' pipe, usually in the center of the 'O'. These images for single or dual exhaust:
This in lieu of the Y pipe, X pipe, or H pipe. It provides 100% back pressure feedback. With the 'O' pipe, torque increase and Kuneutson valve float brings in much lower revs so you don't hurt your engine.
Anonymous Poster #2
Re: Grease Fittings
05/11/2011 11:30 AM
Kneutson's require ball-bearing grease.
http://www.urbandictionary.com/define.php?term=knutson
Re: Grease Fittings
05/13/2011 12:43 AM
LynDoor™ Industries can help.
Our muffler attenuator system is the "bees knees".
The LynDoor™ Industries JointMaster is no slap dash slick trick, it's a scientifically proven solution to those pesky muffler bearing lubrication problems.
WWW.LynDoor.muff.com.
Good Answers: 125
Re: Grease Fittings
05/13/2011 4:21 PM
The site lyn has proposed will certainly lubricate the muffler stiffener rod, but what you need for muffler bearings has been outlawed in the US as it too closely resembled snake oil administered to blondes who frequented garages saying "my car sounds like gazittedood, gazittedood, gazittedood".
Anonymous Poster (3); cuba_pete (1); Doorman (2); lyn (1); Tobugrynbak (1); WJMFIRE (1)
