Previous in Forum: Anti Surge Control   Next in Forum: Instrument Loop Diagram- Numbering Philsophy
Engineering Fields - Instrumentation Engineering - Global Technical Village Engineering Fields - Control Engineering - Control Automation Engineering Fields - Biomedical Engineering - Engineering Philianthrophy Engineering Fields - Electromechanical Engineering - Electromechanical Tacho Engineering Fields - Engineering Physics - Physics change you life Engineering Fields - Energy Engineering - Save earth Engineering Fields - Environmental Engineering - Human Recycle Engineering Fields - Mechanical Engineering - We move earth Engineering Fields - Nanoengineering - Minute study Engineering Fields - Systems Engineering - Systems in Place
Possible Failure of Pr. Transmitters
05/11/2011 12:41 PM
We have used 2 wire fixed range, strain gauge type pressure transmitter of 0 - 400bar for hydraulic press application with output of 4-20mA. Recently found that these these transmitters started leaking from the DIN head and most of the transmitters are without output. Although the line pressure of the hydraulic cylinder is 320bar, what could be the possibility of failure.
One who is afraid to ask is ashamed to learn
Good Answers: 101
Re: Possible Failure of Pr. Transmitters
05/11/2011 5:25 PM
Pressure spikes in excess of the transducer's rated Max pressure.
You need very fast diagnostic equipment to measure instantaneous pressure spikes, a gauge will not show them.
It's not uncommon to have very quick and very high pressure spikes in this type of application. Even the fastest relief valves can allow very quick (milliseconds) pressure spikes in the system. Also you may experience pressure intensification on the rod end of the cylinder, which can be far greater than the line pressure on the blind end. This is due to the difference of area, the rod end can be subject to much higher pressure than the blind end when the cylinder is being extended.
These are my best guesses without seeing a schematic of your system.
Hope it helps.
Get a handheld diagnostic tool such as the HMG3000 by Hydac, and spec in properly rated transducers to measure your pressures.
05/12/2011 1:59 AM
Dear Sir,
Thanks, this point is raising more question about design consideration failure than product failure. As you rightly pointed that there is a very fast pressure cycle.
Thanks Again,
05/11/2011 10:51 PM
In addition, if the pressure pulsates rapidly, the transducer might be subject to metal fatigue.
05/12/2011 3:18 AM
In this case how sould I protect my instruments from failing. We used snubbers but due to snubber presence of the rated pressure cycle we got undesired error of approximately 10 - 15 bar and even higher due to the cycle time is in msec.
05/12/2011 4:02 AM
I think the snubbers are a good idea, but I don't yet understand the 10-15 bar error. It is possible that a hydraulic accumulator shortly after the pump would help to smooth out pressure pulsations (and reduce noise, if that is a factor). Fast-acting valves such as solenoid valves or quarter-turn manual valves might also be issues, but I don't know how much.
Good Answers: 101
05/12/2011 11:36 AM
It sounds to me that you may need to look more closely at your system as a whole rather than point at the part/s that failed. If you are experiencing pressure spikes, and undesirable things, maybe you need to install an accumulator as suggested, and get a higher response relief valve. A properly designed hydraulic system will not damage any piece of equipment used in it. A poorly designed system can have the ability to wipe out components very quickly. It sounds like you need a highly skilled hydraulic guru to take a look at your system to help you find out why you are experiencing these issues.
Register to Reply 6 comments
Jaya Krishna (2); RVZ717 (2); Tornado (2)
