We are making LA steel plate, A516-70. Normilization is at 1650 degrees F, time is dependant on gage.
After normilization there is a natural scale on both surfaces. The problem is when we send to re-level a great majority of the surface scale gets rolled into the plate surface. Present scale removal is just with plant air and blow down the surface.
Our leveller is a a Cauffiel which has enough force to actually put a slight radius into a four (4) inch T plate. However the first pass is low load and the plate is blown down at the leveller exit. The remaining scale is rolled into the plate surface on the second,third higher load passes.
I recieved approval from the CEO to attempt a single plate with a high load on the first pass to attempt to break up the scale to powder.
Am I on the correct path?
Thanks
Ron
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
