I have a fitting with thread on one end. Using my calipers on the threaded end I get a diameter of 10.9mm and using my thread guages I get 1.25mm so is this a 10x1.25 metric piece. What I have tried to find on the Internet is a machine drawing of a threaded rod classified as 10x1.25 What concerns me is the 10.9mm diameter I measured. Is this within the tolerances of a 10x1.25 classified rod or do I have an odd ball thread. I want to couple my device to a long threaded rod using a metric coupling nut but before ordering I need to be sure that the 10.9mm dimension I got is OK.
I am also trying to find a coupling nut with the above metric thread on one end and an inch size on the other. Sort of a "metric to inch coupling adapter". With such a device I can couple my fitting to a more standard, easy to find, threaded rod. Does anyone know if such a coupling nut exists and who sells them. I have tried my best but no luck so far.
