Previous in Forum: Preventive Maintenance and Inventory Management of IT 800xA ABB DCS   Next in Forum: Pressure Sensors Constructed for Sub-sea Level Measurement
Flow Transmitter Not Giving Proper Reading
05/13/2011 1:52 PM
I have DP type flow transmitter (venturi) that has a cal range 0-1250 mmH2O & flow range display is 0-13000 kg/h , it's showing 330 kg/h after many times o trimming it's not going to '0' so any solution? I want to know how to calculate flow at DCS side? What is the equation probably used to do it? I know may be it's silly question but I need simple understanding so asking
Re: Flow Transmitter Not Giving Proper Reading
05/13/2011 2:37 PM
your reading at the DCS is 330 kg/hr even at zero flow condition because for your transmitter sensing the Delta P of just 0.805 mmH2O which is nearly zero but because of the impulse leg variation it is sensing and showing some flow of 330kg/hr.
To avoid this, normally LOW CUT OFF is configured in the DCS and below which when flow goes it will indicate zero flow to avoid impulse line error in actual zero flow condition.
I.E. if 500 kg/hr is kept at lowcutoff then the flow reading goes below 500 kg/hr it will show zero on the DCS. Usually 5% of the flow range is kept as a lowcutoff.
for DCS calculation flow reading = SQT(DP%)*10 %of flow range
in your range if the dp is 312.5 mmh20 means 25% then the flow reading will be:
flow reading = SQT(25)*10 % of 13000
=(5)*10 %of 13000
=50% of 13000
= 6500 kg/hr
05/13/2011 2:49 PM
One small note: Some flow transmitters do the square root function themselves, so there is no need to do that in the DCS. He will have to check the manual and setup on the flowmeter.
05/16/2011 2:42 PM
the pressure range is 0 to 500 mbar how to calcurate ma for 25 ,50 ,75and 100 percentage
05/14/2011 12:50 AM
Check your transmitter catalogue and see if there a parameter called "Low Flow Cut in" on your transmitter. This value might be fixed at 330, the reason why ur instrument is not indicating zero.
Register to Reply 4 comments
A Saleem (1); gkishorenair (1); Kilowatt0 (1); tapasvi (1)
