Previous in Forum: Heat Exchanger   Next in Forum: Water Loss Calculations in a Cooling Tower
Cooling Tower
05/14/2011 1:47 AM
why the level of tank from which pump takes hot water and send it to the cooling tower is maintained at constant level?
Pathfinder Tags: cooling tower
Good Answers: 266
Re: cooling tower
05/14/2011 6:28 AM
so it don't run dry
Good Answers: 48
Re: cooling tower
05/14/2011 6:49 AM
It could be to avoid cavitation in the pump if the hot water is close to vapour pressure.
Re: Cooling Tower
05/14/2011 11:27 AM
Why would it not be????????????????????????
Rule #75!
Register to Reply 3 comments
Holzfeller (1); lyn (1); ozzb (1)
