Previous in Forum: Drawing Abbreviation   Next in Forum: Water Proof
Need Sample Calculation/Books For Car Park Shed
05/15/2011 3:26 AM
Dear all,
I need to design car park shed with contains GI pipes. can any body help me to design?
Re: Need Sample Calculation/Books For Car Park Shed
05/15/2011 9:17 AM
For one car or 1,000? Will tge GI pipes be used as support for the structure?
Please give us a little hint about the project, we don't read minds.
05/15/2011 9:34 AM
Thank you for ur reply.
The length of car park 30m with size of span 5m, width is 5.5+5.5=11m two side parking.
GI pipes is supporting the structure.
Can u give me your mail id, i will forward the drawings, then you can guide me easily.
my mail id: <email removed>
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
05/15/2011 9:53 AM
I do not perform free, long distance engineering consultation, even in areas where I have the credentials. I assume that wherever you are there are no building codes or restrictions. And no pesky insurance company that might want the structure to be built so that it doesn't fall down and kill people.
Civil engineering can't be assimilated via e-mail. You need an education in the field, or in at least some engineering field.
I can tell you that you can find plenty of material property web sites that can provide information on material strengths and properties. Matweb, is one that is very good. (Not an endorsement) So find it, open it and use it.
And finally, e-mail addresses are not published here. There is Private Mail that members can use, if they would bother to read the FAQ's.
Good luck.
Good Answers: 125
05/16/2011 4:18 PM
You need a Structural Engineer for this. You need wind load calculations performed (maybe seismic too) based on your geography (can you remember Haiti, New Zealand, and Japan?) and if you are not going with pre-engineered trusses, you need truss calcs.
Good Answers: 179
05/17/2011 9:08 AM
BTW, does anyone know what the heck a "GI pipe" is? In my 34 years of being an engineer I've never run into the term before. I guess it must be a local abbreviation or term?
There are prefabricated arch type car parks....some feature steel, aluminum, or fiberglass arch frames on which a cloth or plastic sheet is shretched across the series frames. Some others feature steel or aluminum frames and membranes. All frame bases need to be anchored to he concrete slab.
You can find them by either performing a Google search or browsing though Ebay.com.
Why re-invent the wheel when someone already has done it for you, and is most likely available in kit form at a cheaper cost then building it yourself (unless you have access to a huge scrap metal heap and/or free materials)?
Also, you can avoid the building codes and the inspector because such structures are considered "temporary structures".....when you move you can pull it up, box it, and bring it with you to your new abode. One of my neighbors has one that can store his huge RV that's got to be at last 35' long! It's a monster!!!!
05/17/2011 9:25 AM
Thank you for your comments.
Can you tell me what is amount of dead load, windload( with direction) do i need to consider in staad pro design
Good Answers: 74
05/17/2011 1:20 PM
Perhaps you should re-read some of the comments you have already received.
Bruce
Register to Reply 7 comments
ba/ael (1); CaptMoosie (1); lyn (2); muthumadathi (2); WJMFIRE (1)
