Previous in Forum: Food Grows Where Water Flows...How Fast?   Next in Forum: Need Sample Calculation/Books For Car Park Shed
Drawing Abbreviation
05/14/2011 4:50 PM
What is the correct BS 88 abbreviation for Drawing? I need to know I'm drawing a plan..
Re: Drawing abbreviation
05/14/2011 4:53 PM
First guess: Dwg.
05/14/2011 5:52 PM
should I write it in just as Dwg or should I use all capital letters DWG?
05/14/2011 6:46 PM
It may depend on the style preferences of wherever you submit it. Hand-lettered drawings often still use all-caps (such as DWG. 176, SHT.3). If mixed caps/noncaps, Dwg. is good. If it is a filename extension on a CAD drawing, it most usually is .dwg.
Good Answers: 299
05/16/2011 9:12 AM
It is good and standard practice for lettering on drawings to be all capital letters, with no period used.
[edit] Never mind. I see that is rule #1 in the link given by lyn.
Re: Drawing Abbreviation
05/15/2011 10:32 AM
Abbreviations which can be used on drawings
This is a comprehensive list of abbreviations. I found it within 1 minute of beginning the search. Hint, Hint!
If you bother to open it and search some, you will see that it is DWG.
05/15/2011 3:55 PM
Thanks I bookmarked it too.
Register to Reply 6 comments
Doorman (1); lyn (1); phillip (2); Tornado (2)
