Previous in Forum: Good Old UK-tek, Ferranti FM1600B Micro-Computer   Next in Forum: Network Speed Problem
Proper Java Syntax Random
05/15/2011 10:39 PM
What is the New Proper Java Syntax for Global Random Interger Generator ?
Pathfinder Tags: Random Syntax
Re: Proper Java Syntax Random
05/15/2011 11:39 PM
Judging by capitalization, spelling, and word order, you seem to have mastered random syntax already.
Good Answers: 244
05/16/2011 7:18 PM
// Use the Random class of the java.util package
// There are many example in the internet, google it
// Use this piece of code in your program
import java.util.*; // import util package for random class
Random ranGen = new Random(); // you can also pass a seed parameter here
int ran = ranGen.nextInt(); // you can also pass an integer parameter here for upper limit of random numbers, lower limit is 0
System.out.println("The random number is " + ran); // for display the number
// - MS
05/17/2011 1:25 PM
Hey You Thanks.
It was Math.abs....... I've been hacking the syntax.
This is much easier.
Thanks Again
And import java.util.*;
Register to Reply 3 comments
CatBurglerV8 (1); msamad (1); Tornado (1)
