Dear All,
If phase to ground fault occurs in MV System, the voltage of faulty phase drops to zero but phase-phase voltage between healty phases increases ( approximately 1,732 times ). When we use petersen coil how can it detect the faulty phase. Because it compansate the capacitive charging currents to limit phase to ground short circuit current? Is this equipment mono phase or three phase?
And when there is no phase to ground fault in system, is there any capacitive chargin current on overhead line or XLPE cable. Or is capacitive charging current occurs after phase tı ground fault?
Best Regards,
Musa UÇAN
