Previous in Forum: Mechanical Layout   Next in Forum: Steam Turbine Governor Types
Milling Machine Force Problem
05/17/2011 12:47 AM
Respected Members, I am designing a hydraulic fixture for an housing component. there is operation facing and drilling on HMC machine Makino a71. Please give the formulas for calculating force develop in the component while machining and also suggest that how much force apply on the job for clamping. componenet material is alluminium. and clamping device are hydraulic actuators. Regards Mohammad Irfan
Good Answers: 181
Re: Milling machine force problem
05/17/2011 3:23 AM
Asking a question for a second time won't improve the answers
05/17/2011 7:12 AM
Respected Member, I know that this question was repeated, but i am not getting the satisfactory answer. and now across the problem regarding this matter so i asked this question. If you know the answer then please please please help me. hoping positive response !!! Regards
Good Answers: 21
Re: Milling Machine Force Problem
05/17/2011 8:30 AM
I will try to help you understand the question that you are asking. If I took a chunk of material and set it into a vice on a mill and was going to take 2 inch fly cutter to the surface. How much force is it going to take to hold the unit so it can not move while preforming the machine operations.
Is this what you are asking. Or are you asking for the force that is applied to the cutter heads at material interface or cut line?
From here we may better able to help you with the question, if we better understand what it is you are after. If your not sure about the English used to define answer needed, then seek help there 1st.
05/17/2011 9:31 AM
Apply enough feed force to move the cutter through the material at the proper feed rate and apply sufficient clamp force to firmly grip the workpiece.
Hire an engineer to perform the calculations if you cannot arrive at these numbers by experimentation.
Asking the same question over and over will not necessarily increase your chances of success.
05/17/2011 10:49 PM
If you do a web search and study the advice/formula in a site like:
http://www.tech.plym.ac.uk/sme/mfrg315/machforc1.htm
You should be readily able to determine what you need.
The above looks like it has all/most of what you need and took about 10 seconds to find.
05/17/2011 11:40 PM
Respected Sir, Thanks a lot !!!!
Register to Reply 6 comments
fixitorelse (1); lyn (1); mohammad_irfan (2); TonyS (1); TrevorM (1)
