Previous in Forum: Tubing   Next in Forum: Effect of Temperature to Control System (Microprocessor, I/O Modules, Power Supply) MODULES, POWSUPPLY)
S-R Flip Flop
05/17/2011 4:27 AM
can we use S-R Flip flop in Emergency shutdown applications
or is it advisable to used basic gates ( and /or ) and implement SR Flip flop
Regards
Jose
Re: S-R Flip flop
05/17/2011 5:29 AM
If the Emergency Stop function has any Safety implications, it is mandatory to use devices certified as suitable for use in a Safety Related Control System. The integrity level required should be determined by risk assessment methods.
Usually - if logic elements are required - this would mean using monitoring Safety relays.
Re: S-R Flip Flop
05/28/2011 5:39 PM
Yes S-R flip flop can be used in emergency shutdown applications.
Honeywell designed the latest plant safe guarding emergency shut down system and also using the S-R flip flop in application.
Re: S-R Flip Flop
08/27/2011 11:20 PM
Dear Jose,
Depending on what logic you are implimenting, you have to use the appropriate ligical blocks. Either it is normal GATE logics or FLIP FLOPS. Normally in ESD systems we are quite often used the S-R Flipflops where an Emergecy Shutdown (ESD) activates and it trips a unit/plant/equipment and need to to do RESET after the condition of that logic became healthy. Hope you understand.
Register to Reply 3 comments
jamsshed (1); JohnDG (1); panamattam (1)
