Previous in Forum: Plastic ABC Pedal Assembly   Next in Forum: Automatic Braking System
8 comments
98 Neon Tranny Trouble
05/17/2011 11:08 PM
98 Neon tranny Trouble
This is an 4 banger and auto tranny.
My wife has one of those and about two weeks ago it started sounding like a old car from the old time radio show days. where every gear is like whining. You hear it change tone as speed is going up or down.
In addition it's shifting has become erratic. sometime shifting way late, or way too soon,
It even sometimes never gets to 1st gear and you pull away from a stop and you know it's in 2nd because of the slow performance.
Tranny Fluid is at the correct level.
Any ideas as to what could be the problem?
Re: 98 Neon Tranny Trouble
05/18/2011 9:33 AM
restricted filter or line are the cheap options next is trans overhaul time
05/18/2011 9:39 AM
So think a tranny flush that you see advertised every now and than might help?
Joe
Good Answers: 58
05/18/2011 9:51 AM
Joe,
A tranny flush, filter replacement, and fluid fill is your lowest cost option at this point.
Good Luck!
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
05/18/2011 10:31 AM
I've got a spare down Dodgy Dave's lockup on Canvey Island. Just send cash. <Splutter>
Essex jobs for Essex yobs! <Burp>.
05/19/2011 9:07 AM
just a thought its not your power steering pump it would also change pitch with engine speed
Good Answers: 44
05/20/2011 10:45 AM
Classic torque converter. Flush, change filter and refill. Use tranny medic or similar high viscosity "mechanic in a bottle" afterwards. Not much to lose at this point, but the flush may kill it.
05/20/2011 11:34 AM
This is exactly what a local mechanic also said.He said 9 times out of 10 when this is doing this when they do a tranny flush, the tranny shortly dies soon after it.
He said it's more or less toast anyway right now and if it was his he'd just use it till it gets too bad to drive at all. he has had customers do this and some die in a month, and he even has had others go 10K miles more before croaking. so I guess thats what I'll do. just run it till it dies.
Good Answers: 44
05/20/2011 11:41 AM
Yeah, the tranny flush unless done regularly tends to kill them. The varnish in the transmission change the tolerances for the already precision parts inside. Then when the flush dissolves it all the tolerances are all out of whack.
It can really screw things up, messing up the pressure/vacuum balance something fierce.
Register to Reply 8 comments
cuba_pete (2); fire (2); KJK/USA (1); NSS (2); Stinky Pete (1)
