Previous in Forum: information   Next in Forum: Wide Belt Sander 'Contact Roller'
11 comments
Popular Science - Weaponology - New Member Greece - Member - New Member
Furrow on a Glass
04/12/2007 3:20 AM
Who can tell me which is the tinner furrow that i can make in a glass.
I want to get a furrow of 80-100A on it.Is it possible ? And could you tell me if you know a company that can make this.
athmio
Good Answers: 120
Re: Furrow on a Glass
04/12/2007 11:24 PM
80-100 Angstrom furrow in glass? diamond tip or laser
Per Ardua Ad Astra
04/13/2007 2:32 AM
Whatever it does not matter the important is the dimension
athmio
Good Answers: 94
04/13/2007 4:34 AM
Is the finish important? you could make a thin line with a diamond scriber. If you can get a 'V' shaped groove cut by grinding or other machining & it is too wide, you could polish back the surface of the glass to make the groove thinner.
04/13/2007 7:05 AM
I have to make several furrows across a concrete piece of glass
athmio
04/13/2007 6:45 AM
Athmio,
Precitech builds machines for the optics industry. Their sales or applications people may help you find an optics shop for the job. www.precitech.com
04/13/2007 7:07 AM
Thank you
athmio
Good Answers: 266
04/13/2007 9:26 AM
Find a local window manufacturer many have or know some one that can furrow the glass for you.
Popular Science - Weaponology - Scapolie, new member.
04/13/2007 10:18 AM
Hi athmio. What are you making, a diffraction grating for a spectrometer? Spencer.
04/13/2007 12:34 PM
Try etching a furrow. This can be done with great precision. There are several chemicals that can be used and you can vary the concentration to get an etch rate which you can control. A mask may be required.
04/13/2007 12:49 PM
What depth do you need?
There are several methods that could be used, but it depends on your application which would work best with the project.
- grind v-notch and polish down
- etch
- patterned thin film coating on glass (me preferred method)
DK
04/13/2007 2:06 PM
Hi IRDglass. I agree with you. I built my own optical spectrometer using this method. I bought a plastic film of optical grating from a Japanese firm many years ago, then I glued it to a sheet of thin glass. This still works well, and I think that the guy should contact a Japanese optical company. Spencer.
Register to Reply 11 comments
Alvin (1); Anonymous Poster (1); athmio (3); aurizon (1); IRDglass (1); Nigh (1); ozzb (1); Scapolie (2)
