Previous in Forum: Furrow on a Glass   Next in Forum: Time Constant and RPM of a DC Motor?
Wide Belt Sander 'Contact Roller'
04/12/2007 11:49 AM
I hav a wide belt sander that refixing the rubber on the contact roller is a problem, I intend fabricating another one completely madeup of metal 'steel'. Can somebody advise me on this what are the likely obstacts am to face, and what safety precaution should I observe.
User-tagged by 1 user
Re: Wide Belt Sander 'Contact Roller'
04/13/2007 8:31 AM
Several considerations need to be addressed:
What is your application?
What durometer is the rubber (including the composition)
concentricity of the journals of the roll to the body of the core
concentricity of the journals to the rubber exterior
you will have to balance the roll to eliminate any chatter
is your roll a live shaft or a dead shaft ?
why dont you go back to the manufacturer and request a replacement?
Good Answers: 114
04/13/2007 10:02 AM
Yes you Can
The drive can be flat, the driven usually has a slight crown & a way to track, you may have to increase the spring tension to compensate for the lower friction of steel.
Register to Reply 2 comments
You might be interested in: Roller Screws, Flat Belt Pulleys
