Previous in Forum: How Can I Post Sell Information on This WEB   Next in Forum: CMC or Computerised Material Cutting Machine for Prepreg?
High Vacuum Feedthrough For Heated Vapor
05/22/2011 10:36 AM
I need to transport heated vapors into a vacuum chamber (10 to 0.001 torr) from an externally heated chamber. The vapors and transporting tubes have to be kept hot (~300C) in order to keep them from condensing. I'd like to use fluid/gas high vaccum feedthrough which is of the thread/washer/bolt configuration however these usually come with a viton or neoprene washer that can't take the temperature. Does anyone know of a compressible washer that could take 300C (or even higher) in such an application. The conventional thread/washer/bolt gas or fluid feedthrough is quite common. There are good examples at www.ancorp.com, but again, I need to heat this tube to temperatures too high for the conventional washers sold with these products.
Re: High Vacuum Feedthrough For Heated Vapor
05/22/2011 11:40 AM
Welcome to CR4. Why not use a hollow metal seal like they use on sparkplugs?
05/22/2011 12:07 PM
That's a possibility. Not wanting to start a project specifically on designing a new feedthrough for injecting hot vapors into a vacuum chamber I was hoping to find something "off-the-shelf". The "fluid" feedthroughs currently on the shelf come in two varieties. One is just a tube welded to a feedthrough (conflat, KF, and thread+bolt+washer). The other actually includes a double-walled, evacuated tube similar to what you're suggesting. The problem I'm facing with the latter is that I need to heat the entire feedthrough to keep the vapors from condensing. With the hollow tube design, I can heat the outer wall, but the inner wall (which is vacuum insulated) will not be heated, and condensation will occur). The former design of a tube welded to a conventional feedthrough is my best solution but I need to use a thread+bolt+washer design. The best washer solution I have right now is Kalrez which can go up to about 320C (I was hoping to go even higher, like 350-400C). I was just wondering if someone knew of a higher temperature washer (like perhaps a flexible, compressible ceramic). I'm thinking that 320C is the highest that's out there though.
I'll keep the hollow seal idea in mind though. Thanks.
Good Answers: 94
05/22/2011 4:33 PM
Does it have to be a washer seal or could you have a mini Conflat with copper seals?
Never tried this with vacuum but maybe a metal O ring?
05/23/2011 9:56 AM
You need a knife-edge seal to an annealed copper washer/gasket. If you are using High vacuum and vapor transfer, then you MUST use all metal and ceramic and glass components or your seals will corrupt your vacuum and your condensate.
A thin plate of copper silver soldered to the tube as a flange/seal might work for you. Use a large diameter outer and secure it around the perimeter with a steel ring and screws. If this has to be serviced regularly, then the seal ring should be separate from the assembly.
If you could make use of sparkplus for this do it! They are very handy starting points for vacuum systems, including electrical feed through at High voltage and low/high pressures.
Good Answers: 94
05/23/2011 10:46 AM
If you used an alumina ceramic feedthrough the thermal conductivity is sufficient to allow you to fit a heater to the outside.
Good Answers: 130
05/23/2011 8:53 PM
There are silicone rubbers that will cope with 300 C.
Commonly used to seal the ends of tubular heating elements, etc
Dow Corning have such - from memory - no time to do the search for you.
Register to Reply 6 comments
34point5 (1); Dave Albin (1); Deefburger (1); lyn (1); Nigh (2)
You might be interested in: Spring Washers, Labware Washers
