Previous in Forum: Secondary Functional Polyols   Next in Forum: Surface Coating
8 comments
High temperature coating/linings
04/12/2007 7:31 AM
Am looking for any leads for companies having a very high temperature coating or lining material to be applied over our metal substrate. It must reach to temperatures up to 2000F for a 4 hour burn test. The coatings/linings is protecting a concrete structure, however the material is applied to our substrate.
HN
User-tagged by 1 user
Re: High temperature coating/linings
04/12/2007 9:02 AM
I am also looking for any substance which can give better surface finish than
hot dip galvnising on metal, but I have not heared more than 1300f temperature
The Engineer
Good Answers: 129
04/12/2007 9:51 AM
I would recommend 840-m HiE-Coat from Aremco
http://www.aremco.com/PDFs/A5_07.pdf
I found the company by doing a search on Globalspec for industrial coatings and then filtering the result by operating temperature in the advanced filter on the left.
http://materials.globalspec.com/SpecSearch/Suppliers/Materials_Chemicals_Adhesives/Industrial_Sealants_Coatings/Industrial_Coatings?SrchItem=2
04/12/2007 7:26 PM
Kilns that fire to this temp use a ceramic lining. Fire clay.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
04/12/2007 8:57 PM
Our neighboor produce special firebrick, which can be used for iron mill etc. all sorts of shapes. They supply europe and america etc for many years.
I happened to know the factory when I was asked to test their inspection equipment 4 years ago.
Its the first time I saw various shapes firebrick. originally, I know only rectangle firebrick. but when I went into their workshop, I wonderful found there are lots of shapes objects. Long, round, empty, cylindar etc... I was told they are suit to different spots.
so if you need you can tell me the shape, size and quatity...
04/12/2007 9:21 PM
beside this firebrick I also went to some ceramic factory which can be usef for high voltage insulation and of cause high temperature, some of them use for super hard material etc. very interesting.
I know these because they all need inspecting for their quality control.
04/13/2007 6:43 AM
We manufacture a product call Pyrocrete 241 which protect steel structure up to 4 hours in a petrochemical fire situation. We have UL 1709 desing for steel but not for concrete. P-241 can be applied over concrete and will protect your concrete structure. Give me a call if you have an interest in the product; we will see if it can work.
Cell: 514-592-5534 (Mario)
04/13/2007 2:41 PM
Most any Refractory company can supply and apply a gunite (sprayed on) refractory that can do this. Note: The refractory coating may have to be cured via a controlled heat up and various hold times and temperatures. The concrete may have to be cleaned or sandblasted to have the bite to hold the gunite.
04/13/2007 8:56 PM
I applyed a coating over a year ago which is withstanding going from -273 F to +3000 F in 1/2 second.
Jonathan
Register to Reply 8 comments
Anonymous Poster (2); Bayes (1); BrainWave (1); cnpower (2); jagdish (1); jmart23 (1)
You might be interested in: Coating Services, Coating and Spray Booths
