Previous in Forum: High temperature coating/linings   Next in Forum: Optical micrographs from Aluminum alloys
Surface Coating
04/12/2007 9:10 AM
I am looking some one can suggest better coating on steel structure than
Hot Dip Galnanizing, which is equally accepted in terms of technology
User-tagged by 1 user
Re: Surface Coating
04/12/2007 3:31 PM
Apart from the obvious question of why not hot dip what is the coating going to have to protect against and how are you going to apply it?
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Re: Surface Coating
04/13/2007 12:29 AM
Better in what way, cost, durability, appearance? More information please!
An engineer is a man who can do for five bob what any bloody fool can do for a quid (Neville Shute)
Re: Surface Coating
04/13/2007 1:24 AM
There are new coatings available to provide better corrosion prevention. Basically they are Zn-Al flake type coatings applied through Dip-spin, Spray or Dip-drain methods. The coatings are from companies like Dorken from Germany and Nippon Dacro from Japan. These coatings are already approved by major global players for automotive, wind mill setctor.
Nagarajan Ramesh
Re: Surface Coating
04/13/2007 4:45 AM
Belzona 6111 will be equally good. Please consult your local Belzona dealer or belzona.com.
Sisira Amarasekara
Re: Surface Coating
04/13/2007 5:29 AM
Have you considered some tye of epoxy coating similar to what is used on rebar these days?
Re: Surface Coating
04/13/2007 7:46 AM
85/15 Zinc/Aluminum Thermal Spray with Epoxy or one of the new Polymer Coatings used for Offshore may be an alternative.
Looks a lot better and can be Field Applied by Skilled Craftsman.
You see a lot of this on Bridges in Coastal States and in Oil and Gas Fields.
Easy to inspect and confirm Compliance with Standards and Specifications.
I also find this is more Durable than Hot-Dip.
Re: Surface Coating
04/13/2007 6:39 PM
You can use a primer composed of Zinc-Ethyle Silicate to be applied on steel with surfaces prepared to Sa-2.1/2 and apply an intermediate and top epoxy coat to match with the primer. You can get more details for proper systems to be applied to suit your job from paint producers, such as Sigma, Jotun, Hempel, ... etc.
Register to Reply 7 comments
Abdel Halim Galala (1); Anonymous Poster (2); BrainWave (1); nutwood (1); qaqcpipeman (1)
You might be interested in: Coating Equipment, Coating Services
