Previous in Forum: Oil Filled Transformer with Nitrogen Filled. Vaccum is Creating Inside, Why?   Next in Forum: Asking About Branch Breaker
Panel Configuration..Please Help
05/24/2011 3:15 AM
I want to get the configuration & a cost of a panel having outgoing feeders (VFD controlled) appropriate for two 315 KW 4 pole, 50 HZ, TEFC induction motor VFD controlled and two 110 KW 2 pole, 50 HZ, TEFC induction motor VFD controlled along with two 125 amp spare feeders. Kindly help by providing the configuration and the cost of the panel.
Re: Panel configuration..please help
05/24/2011 3:51 AM
CR4 is not as well placed to carry out that request as a selection of panel builders local to where the installation is to be completed, who will happily quote for the task. Try contacting them directly. A Google search will reveal company names, addresses and telephone numbers.
05/24/2011 6:01 AM
Kindly take this matter in other way..
I want to know the process for selecting the motor feeder rating for different system like for DOL starter , star delta starter and VFD drive..
Good Answers: 170
05/26/2011 8:07 AM
Please refer to the type 2 Co-ordination Charts that are supplied on demand by any switchgear manufacturer. They are available for DOL & Star-Delta as well. As for VFD feeders, any VFD manual would give you the necessary switchgear sizing too.
Good Answers: 181
Re: Panel Configuration..Please Help
05/24/2011 7:42 AM
Sorry but my holistic inspiration helmet is away for repair / re-calibration.
With the information provided do you expect a serious answer?
Get in touch with a local panel designer.
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
05/25/2011 7:37 AM
I agree, local panel designer is the only way.
Sure Answers Always
05/24/2011 9:11 AM
Contact a local vendor. This type of information is gained by going to school or going to work with someone who is willing to take the time to teach you.
The local vendor may help you learn, if he can sell you a panel.
Register to Reply 6 comments
electricalexpert65 (1); lyn (1); PWSlack (1); saraswata1981 (1); TonyS (1); Vinu_Answers (1)
