Previous in Forum: K-Value of Flange According to DIN   Next in Forum: Pump Type Confirmation
How to Calculate Spring Creeping?
05/24/2011 5:27 AM
I have a small tension spring (steel) constantly pressed down installed in a unit and I am wondering how long it can stay there and hold the same force? And how much tension it will loose over time how fast - does anyone know how to calculate creeping?
The details of the spring is the following:
heigth before pressed 27 mm
height when pressed 22 mm
outer diameter 25 mm
thread thickness 4,5 mm
windings 4,5
the spring holds a tension force of 978 N on 22 mm.
According to the spring manufacturer the spring won`t loose much tension over time as there were no "red digits" at 22 mm when calculating it on the computer.
What will the tension force be after 30 years, or 50 or 100 years at 22 mm?
Will be grateful for an answer to this!
Cheers!
Good Answers: 183
Re: How to calculate spring creeping?
05/24/2011 6:07 AM
The solution to your problem is to use a pre-stressed spring.
This means that the spring is wound with higher pitch and compressed so that a small plastic deformation occurs. When the spring comes back to its expected free height the zone compressed over the elastic limit is in tension and will not, under load, come again in a compressive status which leads to a loss of tension.
An elasto-plastic FEA program or a computation based on a simplified material behaviour in the elastic and trans-elastic domains can help to define the increased pitch but without tests it is not possible to be sure due to mechanical properties dispersion.
This is used also for valves springs which have to offer same force over time.
The other way is to take a reserve and consider a loss of 5 to 10% and for such periods foresee a check every for instance 5 or 10 years !
05/26/2011 5:39 AM
Thanks,
I will look into pre-stressed springs.
Do you know how long it will take before any loss of tension occurs on a normal spring? (For the other option I will be fine with a 5 -10% loss over 10 years or longer).
Good Answers: 183
05/26/2011 2:51 PM
Impossible to predict without knowing conditions and even in the case they are known there is a broad material properties dispersion which cannot be mastered.
Register to Reply 3 comments
