Previous in Forum: Welding for Cr-Mo Steel & Clading Plate   Next in Forum: Heat Transfer Fins
9 comments
Design Code for Small 0.44 Cu. Meter Chemical Tank
05/25/2011 7:07 AM
Dear All,
we have to design a small tank for methonal storage as follows
Capacity: 0.44 cu meter
Diameter: 750 mm
Height : 1000mm
Can any body tell me appropirate code for designing this kinda small tank. We have used API-650 but thickness calculated is very small as compared to API-650 minimum thickness of plate required i.e 5mm
Thanks for your help
Regards
Re: Design Code for Small 0.44 Cu. Meter Chemical Tank
05/25/2011 8:20 AM
What is the temperature range of the methanol?
05/25/2011 8:30 AM
Temperature is maximum 55C and pressure is atmospheric.
05/25/2011 11:43 PM
You can apply the rules of API 650, taking into consideration the corrosion allowance, and the min. shell wall thickness. May be the shell wall thickness 1/4 inch is sufficient.
05/26/2011 1:08 AM
Dear Abdel,
I was not able to see your comment. Can you please repost it
05/26/2011 6:30 AM
Why does it have to be metal? What about plastics - polypropylene or polyethylene for instance?
05/26/2011 6:49 AM
Our Client want it to be Stainless steel made
Good Answers: 137
05/26/2011 7:40 AM
Sounds like it's a storage tank at atmospheric pressure, presumably covered. I'd make it flat-bottomed, sitting on a concrete slab. 3mm thick stainless steel plenty thick enough.
Codey
05/26/2011 8:57 AM
Dear codemaster,
you are right, 3mm will be more than enough but the problem is we dont have any thumb rule or any strong reference to prove it. if we say api 650 then 3mm will not satisfy the code requirement and we cannot do FEA for such small tank. I am just looking for any equation or theory applicable to these kinds of small tank
Regards
Good Answers: 137
05/26/2011 9:32 AM
You said "We have used API-650 but thickness calculated is very small" so presumably you have the equation. I agree with very small, I make it less than 0.05mm. I'm not familiar with API-650, but I'd be surprised if it has a minimum thickness 5mm for such a small tank. Most vessel specs leave the corrosion allowance up to the designer, and with SS can safely ignore it. If API-650 does say that it looks like you're stuck with it, unless you can find a different spec and persuade your client to accept it.
Cheers.......Codey
Register to Reply 9 comments
Abdel Halim Galala (1); Codemaster (2); PWSlack (2); rafiullah512 (4)
