Previous in Forum: Swab and Chlorinate Newly Installed Water-Mains   Next in Forum: Cutting the Concrete
Use of Copper Slag in Concrete
05/25/2011 10:22 AM
I want to know if copper slug can be used in concrete as replacement of cement. The concrete in question is semi-wet pre-cast concrete used for making pavement interlocking tiles.
Is it possible to use copper slug (waste from furnace) as partial replacement of portland cement?
If it is possible, what are the effects on curing (current curing practice is to simply let the tiles dry under normal atmospheric conditions) process?
Thanks in advance for response
Shakeel Ahmad
Pathfinder Tags: Copper Slug In Concrete
Good Answers: 88
Re: Use of Copper Slag in Concrete
05/25/2011 2:07 PM
Will turn green overtime (?) S.M.
05/25/2011 4:36 PM
I hadn't thought of that, but you are probably right.
05/27/2011 11:33 AM
Is it possible to use copper slag (waste from furnace) as partial replacement of portland cement? YES -but after detailed understanding /research. See these:
· The main kinds of metallurgical slags are:
Fast-cooled iron blast furnace slag (ggbs), steel slag, phosphorus slag,
Copper slag and Lead slag.
Due to their chemical and mineral
composition, these slags have cementitious and/or pozzolanic
properties and can be potentially used as cement main constituents.[This from Greece Research]-----------------
· Non Ferrous Slag products Copper Slag (CS)
Molten copper slag is produced by the reduction of ores and fluxes to liberate the copper metal. It is generally granulated to form very dark colored glassy single-sized (about 2mm) particles. The main use for copper slag In Australia is in grit blasting, due to its sizing and strength characteristics.[ This from Australia]----------------
· The study conducted by CRRI shows that use of copper slag in concrete
have no adverse effect on its strength (Fig.) and a blend of copper slag and
fine sand with slag up to 40 percent can be used as fine aggregate in pavement quality concrete as well as in dry lean concrete.[ This from Indian Road research]----
· Mixed with water, most slags do not generate hydration products. An activator
must be added to trigger their reactivity; activators may be bases such as sodium or
calcium hydroxide4. This is why slags react when added to portland cement, since its
hydration produces calcium hydroxide (in this case named portlandite) as one of the
hydration products.
Using calcium hydroxide it may be possible to experimentally model the reaction
which occurs within the cement paste between portlandite and copper slag. The evolution
of the microstructure with time of calcium hydroxide/slag pastes have been studied. Then
pastes of cement mixed with slag were prepared to observe the modification of the
hydration of portland cement due to the presence of copper slag.[This from Canada]--------------
Register to Reply 3 comments
Doorman (1); MUKULMAHANT (1); SimpleMind (1)
