Previous in Forum: Mv Motor Cable Size   Next in Forum: Explain The Fault Level And Braking Capacity Of Breaker
10 comments
Bus Bar Size
05/27/2011 12:34 PM
My total running load is 1000A , What size do i select for Bus Bar rating .
Re: Bus Bar Size
05/27/2011 12:45 PM
"What size do i select for Bus Bar rating" The correct one.
It concerns me greatly that you are handling 1,000 amps of power without having a clue what you are doing, and I offer you NO HELP. The life you take may not be your own.
Consult someone who has at least some knowledge of proper sizing and handling of high amperage circuits.
Once again, I find myself confronted by someone with absolutely no applicable experience or education who is obviously completly over their technical head asking us to do their work for them.
This is dangerous and unprofessional!
Re: Bus Bar Size
05/27/2011 1:04 PM
Mr. Lyn if its possible for u to reply it will be better if not thanks to u
Good Answers: 181
Re: Bus Bar Size
05/27/2011 1:48 PM
Looking at your past posts, obviously you don't know what your doing.
To ask a stranger on a web site about something so dangerous just beggars belief.
Re: Bus Bar Size
05/27/2011 2:07 PM
Sigh. If this is a schoolwork assignment, read your textbook and class notes and do the problem yourself. The goal of doing the homework is for you to learn and for the teacher to know how much you have learned. If this is a real work assignment, admit to your boss that you do not know how to do this particular task. Building a power distribution capable of 1000A at low or high voltages is not a hobby that people should learn by trial and error.
Re: Bus Bar Size
05/27/2011 2:09 PM
Likely your bus bar should be about this size.
Re: Bus Bar Size
05/27/2011 2:15 PM
This is the kind of bar I use behind my bus.
Re: Bus Bar Size
05/27/2011 2:20 PM
A bus drives up to a bar and asks the bartender, "How many amperes do you think I can carry?"
Re: Bus Bar Size
05/27/2011 2:26 PM
Horse walks into a bar. Bartender says, "why the long face"?
Re: Bus Bar Size
05/27/2011 4:12 PM
Sam Sam,I agree with the other guys. You need to get out of this business. That aside, this question has been asked a 1000 time. You can count them here
Re: Bus Bar Size
06/07/2011 1:05 PM
Select Cu 10x50 - 1250A. It is Standards Russia
Register to Reply 10 comments
life 220 (1); lyn (3); redfred (3); samsam_sam45 (1); TonyS (1); wareagle (1)
