Previous in Forum: Icebox Insulation   Next in Forum: ASME VIII
ASME VIII
05/28/2011 4:02 PM
1. When you are reviewing PWHT & RT inspecting sections in ASME VIII code, you will observe that Both PWHT & RT full length are not mandatory for Stainless Steel, P no. 6, 7 & 8 even if for thick sections. Is this because that the welding defects are rarely induced in St. St. welding, so we are not in a need for the full length RT, and the residual stresses are, also, rarely induced during the welding process so PWHT is not mandatory? Can you discuss?
2. In ASME VIII, UW-11 Radiographic and Ultrasonic Examinations of Weld Joints, the following welded joints shall be examined radiographically for their full length:
· All butt welds in vessels in which the nominal thickness at the welded joint exceeds 1-1/2 in. (38mm), or exceeds the lesser thicknesses prescribed in UCS-57.
Then when we read to table UCS-57
We find out that, there is no value exceeds 1.5" mentioned in the preceding paragraph. I think there is confusion, could you explain the difference?
Ask right person to get the right answer.
Pathfinder Tags: ASME VIII
Re: ASME VIII
05/31/2011 8:33 AM
Tal,
While you would most likely need to consult with the board of authors for this Code to find the absolute correct reasons for not providing the provisions for RT for those P numbers, the likely answer is because of design with s/s materials. You may also note that the Code does not provide for RT on 18" thick s/s materials. Why you may ask? It is simply because for Boiler and Pressure Vessel applications, you simply do not find components manufactured in that thickness. The same likely holds true for anything over 1.5" thick. Or, in the rare instance that you would find anything made in that thickness, the quality level of that component need not be very high where it would require RT inspection.
Again, I note that you have posted quite a few Code specific questions. As a suggestion, I would perhaps look in the front of the Code to find a list of the authors and/or contributors. Maybe you could Google them to find contact info. Even if one specific person couldn't answer your questions, he/she might be able to put you in contact with another contributor who could.
Good luck! And when you do find the answers, please come back and share with the rest of us.
Re: ASME VIII
06/01/2011 4:23 AM
thanks
1- (austenitic Stainless Steel can not response to PWHT) this is one reason do uoy have another reason for ferritic Stainless Steel???
2-
(Table UCS-56-1 Applicable Only When Permitted in Table UCS-56)
see also note (3) for Table UCS-56 P no. 5-A
((3) When it is impractical to postweld heat P-Nos. 5A, 5B Gr. No. 1, and 5C Gr. No. 1 materials at the temperature specified in this Table, it
is permissible to perform the postweld heat treatment at 1,200°F (650°C) minimum provided that, for material up to 2 in. (50 mm) nominal
thickness, the holding time is increased to the greater of 4 hr minimum or 4 hr/in. (25 mm) of thickness; for thickness over 2 in. (50 mm),
the specified holding times are multiplied by 4. The requirements of UCS-85 must be accommodated in this reduction in postweld heat treatment.)
Re: ASME VIII
06/01/2011 4:28 AM
( the nominal thickness at the welded joint exceeds 1-1/2 in. (38mm), this for any P. No except the P. Nos in UCS-57 use exceeds the lesser thicknesses prescribed in UCS-57)
Register to Reply 3 comments
