Previous in Forum: Transformer   Next in Forum: DC Drive, Heat Required to Kick Start
Fiber Optic Cable
05/30/2011 5:49 AM
Dear Members
I would like to ask your help regarding the above subject.
How to order fiber optic cable our spec call for at least 6 fibres less than 15km for single mode this is for main fiber optic cable. Hereunder are the specs;
single mode, index-gradient: 125um
core diameter: 9+/-10um
cladding diameter: 125+/-1um
coating diameter: 250 +/- 10um
Non circularity of the core <3%
Non circularity of the cladding <1.5%
Concentricity deviation < 0.75um
Max. attenuation of the signal at 1310nm<0.4dB
Dispersion coefficient at 1310nm <3.5ps/nm
max. attenuation of the signal at 1550nm<0.23dB
dispersion coefficient at 1550nm<18ps/nm
Cut off wavelength<1280nm
I hope somebody can help me who specialize in this field.
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
Re: Fiber Optic Cable
05/30/2011 7:27 AM
CR4 team is not expert in placing orders, better you rush to local vendor.
Sure answers always...
Sure Answers Always
05/30/2011 11:04 AM
Find some vendors of fiber optic cable and send that specification to them. Local (as Vinu Answers suggests) or not so local.
There are some things that don't seem to be specified above. Probably wherever you install this cable, you will want an outer jacket around it (made from some variety of plastic).
Engineering Fields - Systems Engineering - Member for some time now, see my profile.
05/31/2011 8:50 AM
hi, some of us have already responded to this question.
You need to work harder on your requirements. Like Mechanicals, Environmentals, Installation issues etc.
You have to get to grips with what you are trying to achieve!
Sleepy
Register to Reply 3 comments
rhkramer (1); Sleepy (1); Vinu_Answers (1)
