Previous in Forum: 99 Buick Regal Stereo   Next in Forum: Vertical Turbine Pump Service Facilities India, South Africa
Instruments Not Working
05/30/2011 6:32 PM
all dash gages are out, tachometer, speedometor, odeoeter/tripmeter, fuelgauge, lights are all out, would this be a fuse or something else, and if something else, would it be easy to fix? optima ex 6 cyl, 2004
Good Answers: 70
Re: jparue
05/30/2011 7:06 PM
If you know your battery has at least 12 volts and you have power to other things in the car, dome lights etc., then the fuses would be the first place to start, (2) then the wire connection on the back of the Instrument cluster, then (3) the ECU. But being you've lost everything, I'd suspect a fuse to the ECU. I don't have a wire schematic in front of right now to be able to tell you which fuses feed your ECU.
Good Luck and let us know what you find. DJ
Re: jparue
06/02/2011 12:06 PM
went and had it tested, it turnes out that the cluster was gone, had them put a new one in(from junk yard) works fine, thanks for everything
Good Answers: 70
Re: jparue
06/02/2011 5:43 PM
Thanks for letting us know what you found out. DJ
Re: jparue
06/21/2011 6:12 PM
I.P.V.R.
MSME/ D Eng./ SAE lifetime member/ father/ GT500 driver
Re: jparue
05/30/2011 7:07 PM
You are going to have to provide a lot my information before anyone can start to answer your post. For starters, does the engine start and run?
Mr.Ron from South Ms.
Good Answers: 44
Re: Instruments Not Working
06/01/2011 10:56 AM
Yes, no...maybe.
Buy a test light and go for it!
Register to Reply 6 comments
cuba_pete (1); dj95401 (2); JPARIES (1); ronseto (1); Sundog (1)
