Previous in Forum: Noise in Test Equipment   Next in Forum: energymeter calculation
Transient Value in Fault Current?
05/31/2011 7:48 AM
As we all know that there is transient value of fault current before it achieves the steady state value and it is due to d.c but i want to know how come this d.c part,Kindly explain?
Regards,
Saurabh Sharma
India - Member - New Member
Good Answers: 164
Re: Transient value in fault current?
05/31/2011 7:55 AM
This document can perhaps help you : ect158.pdf
Good Answers: 170
Re: Transient Value in Fault Current?
05/31/2011 9:37 AM
Well! Any electrical system would definitely have network components such as resistances, inductances & capacitances. The resistive network components would dissipate energy in the form of heat, whereas the reactive components would store energy. Remember! Energy stored in an inductor is 1/2 L I(square) and the energy stored in a capacitor is 1/2 C V (square). Till the moment of fault, current would have been flowing in these system components and the resistive components would have dissipated their I(square) R t Enegry in the form of heat. But, the reactive components (both inductive and the capacitive reactances) would have stored energy. And, at the instant of fault, the voltage applied to these network components becomes zero, post-fault point. This is akin to switching OFF supply to these reactances. When the supply to a reactance is switched OFF, the energy stored in the reactor is DC in nature (at the instant of switch OFF, one terminal would be more positive with respect to the other terminal). So, these reactances would act as DC accumulators. As the fault is also a short circuit at the terminals of these reactances, they would discharge thro the short circuit. As the stored energy in these reactances is DC in nature, the discharge current would also be DC in nature. But, as these are finite sources, their current feed into the fault would last only for a few cycles, the time constant decided by the system R/X ratio. Hence, they are transient in nature.
Hope it is clear!
Good Answers: 244
05/31/2011 9:57 PM
This is good answer. This comment of a previous thread also help:
http://cr4.globalspec.com/comment/646542
- MS
Location: City : Chandigarh, Country : India, Continent : Asia, Planet : Earth, Galaxy : Milky Way, Universe
06/01/2011 12:32 AM
Hats Off Huzoor !
What a simple explanation of complex question...absolutely no distortion... Thanks
Regards,
Sanjeev
Karma is Dharma
Register to Reply 4 comments
chhotu1990 (1); electricalexpert65 (1); kvsridhar (1); msamad (1)
