Previous in Forum: Transient Value in Fault Current?   Next in Forum: Synchronous Motor
energymeter calculation
05/31/2011 11:27 AM
what is the procedure to get power consuption of blower if there is energy meter installed.in my plant i have to calculate power consumption of blower n energymeter is installed.others hav noted only readings shown on to display of energ. daily.bt sum tim they hav noted instant value n sumtime from d relay
Re: energymeter calculation
05/31/2011 11:37 AM
Average energy consumption rate is the difference in the two readings divided by the time interval between them.
Good Answers: 181
05/31/2011 4:05 PM
For our OP
avg NRG consumption R8 iz d difference n d two readings divided by d tym ntrvl Btwen dem
Sorry PWS
06/01/2011 3:53 AM
"That's simplode a three-four you to say." - Stanley Unwin.
Good Answers: 804
05/31/2011 12:55 PM
ENERGY is power over time. Instantaneous readings would be power ONLY. They are different entities.
05/31/2011 11:41 PM
Install a power analyser and record Watts during a period of either 08 or 24 hrs,from which you can get minimum,average and maximum power consumed.
pnaban
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
06/01/2011 7:27 AM
If energy meter is installed for your blower. Then, see the Multiplying Factor (MF) on Energy Meter Name Plate.
Then Energy consumption is obtained by the reading on the energy meter reading on the display multiplied by Multiplying Factor (MF).
Vinu_Answers Sure_Answers
Sure Answers Always
06/01/2011 7:32 AM
Dear,
Energy consumed in the time interval t2 - t1 can be expressed as
Energy in KWH units = (Reading of KWH meter @time t2 - Reading of KWH meter
@time t1) * Multiplication factor of metering system.
Multiplication factor = CT ratio * PT ratio
----------------- * scale factor of meter.
meter CTR * meter PTR
I can clarify that dividing the dif. of 2 KWH readings by time interval shall give you average KW load ( unit of power )on the system during that time.
Exploring the Science of Electricity
Register to Reply 7 comments
harry potter (1); JRaef (1); pnaban (1); PWSlack (2); TonyS (1); Vinu_Answers (1)
